I just bought Denon 1910 and connected it to my PS3 80 GB (trough HDMI cable). There are 2 questions on which I need help:
1. Should I set the PS3 on bitstream or linear settings? When it is on linear, Denon's display shows something like multichanel in ,and if I switch to bitstream it shows weather it is DD or DTS, but I am getting a message from the PS3 that some contest of the BD will not work properly. So which one should I apply? And is it true that the PS3 can not send the HD formats uncompressed?
2. I played regular DVD (turned the upscaling on the PS3 off). I expected that my Denon would do the upscaling but it didn’t. How shall I set it to do the upscaling?
