The Pro-Ject VC-S arrived today in a bigger double box(well..compared to the Knosti) and it's pretty heavy. Installation is quite simple and easy, just screw on the small platter, insert the vacuum tube and of course the power cord (Youtube always helps). A small 50ml of liquid cleaning solution is included and 500ml of empty plastic bottle for the mixture. Now for the plus side..I was amazed how my records got cleaned in no time without rinsing and waiting for them to dry thanks to the very powerful vacuum. Each lp just took an average of 3 min. both side from start to dry finish.
The included Pro-Ject clean IT solution does the job really well without any residue on the vinyl. Just mix 1:10 or 1:20 with distilled water but this varies on how dirty the records. The cleaned records looks like they were new and sparkly.
Now the negative side..The motor is a bit noisy and the vacuum is as loud or much noisier than our Henry hoover! Over all Im quite satisfied and happy with this purchase and I strongly recommend the Pro-ject vcs if you have large collection of vinyl records or planning to do so.
@Al ears.. I think you need to get one sir!
