Seasons greetings
after much consideration i made my mind up to purchased a pair of pmc 21 to replace bw cm5.
so my impressions on them will be more of a comparism between 21 and cm5.
PMC's packaging is very good both the speakers and mathcing stands were well packaged, assembly was straight forward although an extra pair of hand would have made things a lot easier. screw whole alginement on one of the top plate and front pole was slightly out , altough its only a small issue but when you are paying that amount of money you expect everything to be just perfect specially coming from a company like pmc. so i ended up using onle 3 screws instead of 4.
first thing you notice about them is their light weight, they are only about half the weight of cm5. they felt lighter than my wallet felt after i paid for them, if you know what i mean.
21s on their dedicated stands do look but on that particular department cm5 is atleast a few miles ahead of them and it does not help either being constantly remided that "your old speakers looked a lot better" by wife. she even said cm5 = marilyn monroe and 21s = duches of cambridge.
now to real deal and i think i have given 21s fair enough time to base my judgement ..i never knew 2 different pair of hifi speakers can sound so much different from each other. Compare to cm5 they do sound a lot more neutral and accurate, they dig deep into the mix, instruments are a only tad bit better separated but there is quite a big improvements on bass department and i can see why pmc keep banging on about their ATL techology, highs are well rounded and theres no unnecessery sharpness, vocals sound just as good as they need to. however cm5s do produce a lot wider sound stage where as 21s give more like point and shoot sound, thats not to say that their sound staging is bad. cm5's slightly sharp highs and a little exaggerated bass with a bit of coloration. they certainly give you the WOW which, 21s being more neutral, dont give. 21s are not every1s cup of tea, altough i dont regret buying them, for my taste i should have atleast demoed the cm5 s2.
plastic penguin stated in 1 of his post that 21s are overpriced, i couldnt agree more with him at the same i would say their 20 years gaurantee adds a little justification to the price tag also whifi's review about 21s not sounding good at low volume is utter rubbish.
these speakers deserve to be given more time, not for them to get any better but for me to get used to them. is it worth the price difference between them and cm5? as much as i would love to say yes but the honest answer has to be no.
world doesnot have to end with 21s, few years back i couldnt even dream of buying such speakers may be one day i would be in a position to demo bw 805 or kef reference. as they say; never say never.........
thanks for reading
thanks for reading
