Please help me choose between some AV Recievers!
Phil77
I have been trying to choose for the last 3 weeks between some recievers
The Denon 1910 is suppose to be amazong but i have been to look at it 3 times and the build quality compared to my onld Sony ES Amp is simply shocking its like a plastic toy there is just to much plastic and fair enough i have not heard it but this has put me off
The Yamaha 7065 is better built also £350 which is £50 cheaper than the Denon at the moment but does it sound just as good?
My final choice is the older but better built Sony STRDA3200ES all i want the amp for is to connect to my blu ray player so this will do me fine and also abit of stereo performance this is currently new at £330
Please guys give me some quick advice i'm going nutz!!
my speakers are Q Acoutics 1050i
Have you considered an Onkyo TX-SR607? I have a 605 and it's an all metal affair, built to last and one that produces a muscular, energetic sound. I suspect the 607 will be very similar or better in all aspects.
we all have are interpretation of what sounds good, my advise would be to listen to the 3 amps you have shortlisted and let your ears make your mind up. don't discount the denon on looks it got ***** for a very good reason.
