before I start I want to you to please show understanding to my complete lack of knowledge.
I have:
Marantz PM6002 stereo amp
a pair on Monitor Audio BX2's
a pair of B&W DM110i vintage speakers (tweeters are dead)
Recently I have bought a B&W AS608 woofer and I am not sure how to connect it properly. My amp doesn't have a dedicated woofer output and I am not ready for an upgrade.
I made some research on the internet and I found out that I need to connect it at speaker level - one pair of speakers and the woofer connected to the same speaker sockets.
QUESTIONS:
Do I have to use some splitter banana plugs (is this what are they called)? I have seen a guide on the internet in which dude used those but hasn't explained if it has to be done this way.
Can I just plug the bare wires - both speakers' and woofer's- in the same outputs?
Which speakers should I connect to the same outputs with the woofer?
What cable should I use to connect the woofer? I have read that 16-thick or less.
Thanks!
I have:
QUESTIONS:
Thanks!
