So the Panasonic DMP-BD55 is discontinued! No one selling it (okay maybe one or two places) and not on their website anymore!
I have just bought my first proper 1080p 24fps 46inch tv, and was gonna buy the BD55 to go with it (on whathifi's recommendation), but now that it has been discontinued I am suspicious. I might still buy it, but should I op for the cheaper BD35?
I think cnet says that the video quality is the same on both (Panasonic appears to have told them that), and that unless you will use the 7.1 analogue outputs go for the BD35.
I won't use the 7.1 outputs.
I know I should, but I do not own an AV received yet. I will only be using the hdmi ports straight into my new tv.
So...does anyone know if given the above I should stick with the BD55, or should I go for the cheaper still 'massly' available BD35, which has or has not the same quality, 'digital sound and visual-wise' ??
