ONKYO606 SETTINGS ARE THESE CORRECT
Under Speaker settigs this is how it is setup:
Speaker Configuration.
Front 100Hz
Centre 100Hz
Surround 100Hz
LPF of LFE 120Hz
Level Calibration
Left 5.0dB
Centre 6.0dB
Right 5.0dB
Surr Right 8.0dB
Surr Left 8.0dB
Sub 12dB
Is this correct i have two little kids that have a habit of keep pressing buttons on the amp:)
left 3.30m
centre 3.30m
right 3.30m
surr right 1.20m
surr left 1.20m
sub 4.80m
hope this is some help
Andrew Everard
1,878
Not really - also depends on the layout. furnishing, acoustics of the room and all sorts of things.
Basically if the distances are accurate and it sounds fine, no problem...
Oh, and to keep little fingers at bay, you can lock the set-up once you're happy it's OK. See manual p82.
Cool have a look at that.
Is there a way of getting something like the magic eye for the reciver cracks me up having to keep open all the time
Hi,if you look under the menu there is a lock settings function.
Andrew Everard
1,878
mike0619:Is there a way of getting something like the magic eye for the reciver cracks me up having to keep open all the time
You need something like this.
simoncar:Hi,if you look under the menu there is a lock settings function.
Note to self: ask JD to turn off the Forum echo function...
