Power conditioners
spl84
127
77
670
I have some issues with interference, nothing major but just some little sonic artifacts coming through my speakers from time to time and would like to know if they could be helped by using a power conditioner. The most noticeable things are the light popping sound I get when I am listening to my records and I also happen to be cleaning a record on my VPI Cyclone. If I flip on the cleaning platter or the vacuum I can hear an audible pop coming through my speakers. I used to play electric guitar in this same room and would also hear these sounds come through my guitar amp when I would turn on another electronic device. Would a power conditioner connected to my stereo fix this issue?
Reactions: Kenneth Fernandes
twinkletoes
956
714
5,770
a power conditioner wont help with a feed back loop arguably wont help with anything.
The only thing that will help with that is a battery back up power supply, like that used in Offices so that computers can be safely shunt down in the event of a black out. It should smooth out power supply as you're drawing from the battery all of the time.
Somthing like this
abacus
1,348
1,176
21,070
Sounds like the house wiring may need checking for loose connections etc. (When were the electrics last checked)
Try a simple surge suppression block and plug the most sensitive equipment into that, otherwise as AI ears says.
Bill
Kenneth Fernandes
149
15
95
The only way to know for sure is get a cheap one and try it. If it fails you could be looking at a mains regenerator which is big money.
The best replacement for StopWatt is a high-capacity battery pack, like the Tesla Powerwall. And the greatest improvement would come if the Hi-Fi gear could directly power on the battery.
spl84
127
77
670
I think all my hifi equipment is already on a surge strip. I will try to plug everything else into one and try that.
twinkletoes
956
714
5,770
Never hurts to base replies on what seems actually to be happening though.
And whats that exactly?
"sonic artifacts coming through my speakers" well this could be anything a ground problem is the most likely cause from a device like a fridge, mircowave, boiler, storage rad, digital clock, lights etc or a crusty switch in the house and/or in any one of those devices this will manifest itself as what is commonly called feedback when heard through a speaker :rolleyes: basically its a rats nest is anybodies guess.
"light popping sound I get when I am listening to my records" this could be pure coincidence and be static arcing to the needle, very possible this time of year and he said it was intermittent.
Is that better addressed all.
Buy this and never suffer same problem again and enjoy an actual uplift in sound quality.
Amazon.co.uk
or do what Kenneth has suggested
nopiano
Does the noise coincide with using the power on-off switch on the cleaning device? That’s how I’m reading it, so it sounds like the switch isn’t in good shape or should be isolated from your system.
A dodgy switch or one that needs something to stop it arcing, will pop through your system, especially with MM or MC inputs selected and the volume up. Does it still sound when say CD input is selected?
Unless it occurs during actual listening, it would be better to turn off the Hifi, or maybe just mute it, when using your record cleaner.
spl84
127
77
670
Yes. Sorry I needed to clarify that. In my original post I kind of made it sound like I was hearing all kinds of noise. I'm just hearing a popping when I flip the switch to turn the platter on. It has a 3 way switch(off, fwd, and rev) it also has a 2 way switch for the vacuum system. I need to test it again to see if the vac is also causing popping but the platter switch is definitely causing it. I will also check other inputs to see if those are complicit.
Reactions: nopiano
good_enough
129
90
18,670
My tuppenceworth: an arc is being caused when you flip the switch. An arc emits broad spectrum RF and this is being picked up somewhere (when Marconi 'invented radio' he basically just made an almighty spark and detected the same 'pop' you are hearing!)
Does this vary according to which input you have selected? If it's happening on phono only, the minuscule radio energy is likely being picked up by the turntable wiring along the tonearm. If on any input, then your pre-amp is very poorly shielded.
Reactions: spl84
busb
90
12
Doesn't sound like feedback but switching noise. If the case, I would try to find the source such as anything with motors: central heating pumps, shower pumps, old fridges etc. In other words can you isolate the cause? If found, either fixing, replacing or filtering the source before it gets to your stereo would be my way forward.
If your house wiring is old, maybe getting it checked might help, especially as it happened with your guitar amp.
Gadusmorhua
101
91
670
I spent a modest sum on a power strip, which seemed to reduce artefacts produced by appliances. A big chinese freezer in my barn was the main culprit. One shower pump still causes a blip in streaming when it comes on, which is hardly ever, fortunately. Things like that annoy me, even though it is milliseconds.
Reactions: spl84
Roog
87
86
18,620
Sounds like it’s noise generated by other equipment in your home, lighting for instance.
I would attempt to find out what is causing the noise which could be air borne RFI or transmitted via the mains wiring or both, then solve the problem rather than trying to mask it by using conditioners.
I have a very new wiring system in my home and I don’t get noise issues from it or appliances around my home, try tosolve the problem (from your description it could be a worn light switch or a particular light bulb/lamp).
