Oldskool Pioneer amp broken
I have a Pioneer A88-x amp which has all of a sudden decided to stop working (it's not the fuse in the plug)
nothing happens when you press the power button, but when you press it again as if to turn the amp off it makes an internal 'click' telling me there may still be some life in it?
does anyone know what this could be? and/or if this is a common fault? and/or if it will be costly to put right. also does anyone know how much the amp is likely to be worth, if anything??
many thanks in advance!!!
not sure really however, you may want to take the lid off (whilst the unit is disconnected from the mains) and check inside - there should be some glass fuses (quick-blow) inside. check them and replace if blown. also check for burning smell - if there is a funny smell then bin it.
