I got it at a good price, although the overall cost inc screen extra cable, power, black velour, wood etc has been as much as a half decent used family car.
When you look at some content you think I need 4K - then you look at other content like Kong upscaled to 4K and think - I can happily live withh upscaled 1080p. Dont get me wrong I can clearly see where the extra resolution will be a big benefit to me especially sitting so close. 100 inch at less than 8 feet I will see the full benefit
Its the contrast of the image that I need to do my best with - not the brightness, the PJ is very bright its the blacks - thats what gives the image more richness.
Thats never going to be the strong point of a PJ setup - I also had to buy the Seymour UF material which I have found much to my delight - if I turn up the PJ brighness - not actual black level brightness - I mean Iris brightness control I have been able to get from memory the "Pop" to the image that I saw from the Seymour XD material that made me fall in love with a projector in the first place - I am thrilled by that. I can improve on this also a bit I think.
I am at 75% brightness which means nothing, I can go higher for more "Pop" - but If I go higher the material weave is more visible on scenes where its a big areas of lighter - such as sky and cloud etc
Thats a setaing position limitation - but sitting this close makes it feel bigger than it is to a degree and very immersive
