Hello I am a long time lurker but first time poster.
I am need of advice, I have just brought a
Tacima 6 Way Mains Conditioner and Radio Frequency Interference Filter CS929C/BP and a Merlin Tarantula Figure '8' mains cable to go with my AV setup
My Av setup:
Onkyo TX-SR608
Samsung UE46C8000 3D LED HDTV
Q Acoustics 1010i 5.1 Speakers
Sky+ HD
Playstation 3
Xbox 360
And they are all connected to my amp using the best HDMI cables and interconnects and all the above equipment is connected to a Masterplug Master series 8 way surge block.
I am wanting to now connect the above to the new Tacima CS929 but have been been told that I should not connect the Amp and Subwoofer to the Tacima as it strangles the amps power.
So my plan is to Connect the HDTV, Sky Hd, Playstation 3 and Xbox 360 to the Tacima and then the Amp and Subwoofer to the Masterplug Master Series surge block.
What do you think? Is this the best way and also in what corresponding order do I plug the equipment into the Tacima?
Then I am going to use the Merlin Tarantula Figure '8' mains cable on my Sky+ HD box.
I wanted to replace my onkyo and TV mains cable but they cannot be unplugged as they are not removable leads.
Thanks in advanced.
My Av setup:
Onkyo TX-SR608
Sky+ HD
Playstation 3
Xbox 360
Thanks in advanced.
