Al ears
drummerman said:Fred Scuttle said:Nothing on the mains can have any effect on performance. You're all hearing placebo.
Now we know once and for all ...
I heard a placebo once......
Oldphrt said:ellisdj said:Its funny watched a clip of Jeff Rowland talking yesterday about on of his new products a power supply with a bonkers amount of Caps in it.
His words are - nothing gets through with that - its amazing how much better the sound of a system is when you eliminate the noise on the mains hmmm
An amplifier would hum like the clappers if it couldn't eliminate the noise from the mains.
Al ears said:Oldphrt said:ellisdj said:Its funny watched a clip of Jeff Rowland talking yesterday about on of his new products a power supply with a bonkers amount of Caps in it.
Possibly, always assuming you had a very shitty mains supply which some of our foreign posters may indeed have.
britain4 said:Well I think the degradation in sound could have been something to do with all the new caps breaking in and nothing to do with the Hub because boy has it opened up the last couple of days, it sounds lovely now, it’s amazing what these old speakers can do. Haven’t even rewired them yet, still rocking the crusty old thin base metal stuff, got some Van Damme Blue to use when the binding posts arrive.
Lucky old me’s also been given a Power Chord which should be an upgrade to the Clearer Audio ones for what it’s worth so that’s powering the amp now (got the Russ Andrews filters in the CD63 so thought the amp might benefit more?)
Anyway put it this way I am definitely a believer in mains filtering having repeated my A-B tests tonight now everything has had more time to settle in!
Oldphrt said:britain4 said:Well I think the degradation in sound could have been something to do with all the new caps breaking in and nothing to do with the Hub because boy has it opened up the last couple of days, it sounds lovely now, it’s amazing what these old speakers can do. Haven’t even rewired them yet, still rocking the crusty old thin base metal stuff, got some Van Damme Blue to use when the binding posts arrive.
LOL.
SemiChronic said:I think im scared. When i got a new amp and streamer, i also got a tucana mains conditioner thingy. It wasnt an impulse purchase, being sensible i wanted to protect my stuff.
Ive used it from the off and everything sounds great, no pops or smears. Never had my amp plugged directly into the wall socket. But this thread is giving me the the "What if?" random nagging . .
To be sure it's not just what you were expecting, switch back in a few days. Sometimes things sound better just tidying up the wires, but I think that's more imagined than real!SemiChronic said:And im very pleased and embarrased to say "Its better"
Seriously i feel like such a twonk. Should have done it about a year ago.
Im useless at describing sound, Its a definate improvement. Everything sounds more Alive
SemiChronic said:Amp plugged directly into the wall(At the expense of twig lights)
And streamer and cd plugged into leema tucana mains conditioner thingy.
Yes, i think i will leave it like this providing the mrs doesnt throw a wobble re: pretty twigs
SemiChronic said:Thats pretty much how id describe what the tacima was doing, strangling the amp.
Ive swapped cables before and the mrs has noticed, so i'll see if she spots the change in sound without mentioning it.
Oldphrt said:SemiChronic said:Thats pretty much how id describe what the tacima was doing, strangling the amp.
LOL.
britain4 said:Well thank you for the interesting and informative post... *dash1*
CnoEvil said:britain4 said:Well thank you for the interesting and informative post... *dash1*
In a forum populated by amiable nutters such as myself, who have heard the same effect and are trying to scramble your brain with our audiophile nonsense....you should be thanking Oldphrt for his science based, common sense.
But the conspiracy goes deeper. The manufacturers of conditioners, design their products to preserve high current delivery, rate their products with the max amps/watts they can deliver and have unfiltered sockets for amps. This is not because it's necessary, but because it enables them to charge excessive sums of money, to us nutters, who think such things matter (generally as a result of having read their impressive sounding, but foo-based marketing).
Now this isn't the end of the story. If you have taken the red pill, you will stay in Wonderland and see how deep the rabbit hole goes.. The manufacturers of amps are also part of the collective delusion and queue up to reinforce the narrative.
Sugden:
“We don’t use mains conditioners but if somebody wants to, they need to make sure it has the correct power rating. Line level equipment such as CD players and pre-amps have very low power consumption but Integrated amps and power amps require a mains conditioner of much higher rating. Using a mains conditioner assumes the equipment needs it. We spend a lot of time designing our power supplies and carefully choosing the rectifiers, transformers and smoothing capacitors. From my experience, most conditioners used on power amplifiers reduce the dynamic range. The best power supply for a system is a separate spur from your fuse box, this might even be less money. I am of the opinion you need to be as direct to the mains as possible with our class A amplifiers.
Experimenting with an isolation transformer is interesting and quite a big one isn’t too expensive to run amplifiers from.
Sorry I can’t offer any definitive technical support but as our mains conditioning experiences have been quite negative we have left it alone.”
Gryphon
"In our experience, most external powerline conditioners do more harm than good. The sound may be very different, but not necessarily an improvement. Listen very critically and for an extended period of time, before making a final decision about purchasing a conditioner.
Gryphon products incorporate heavily regulated multi-stage power supplies which act as effective mains conditioning filters and will in most cases not be improved by the insertion of an outboard powerline conditioner in the signal path."
Plinius
Most mains conditioners or filters act in series with the mains and will starve the amplifier and negatively affect the sound. Look for a brand that works in parallel. If you need this treatment to your mains supply, this is a better option for you."
Lavardin
"Most of the power conditioner and other "filtering" devices are designed to provide a certain immunity to adverse signals, voltage and current. Manufacturers are happy to demonstrate the effect of their filters. This kind of protection is more than necessary when it is about dental surgery electrical appliance !!!! Concerning your hifi system, unfortunately, most of what they do is the reverse of what could be beneficial for the sound. A Hifi system is not a piece of hospital electronic gear. This comes from wrong understanding of the problems that should be solved. Now, when this kind of equipment is used with traditional hifi gear, it brings some effects and some times it is not worth than any thing else : it makes somes changes. But does it improve the sound ?"
So there you have it. Oldphrt has a vocation to make sure that audiophoolery is kept to an obsolute minimum and save the sanity of those who have not yet been irretrievably drawn to the Darkside. An admiral goal.
But this isn't the end of the story. If you have taken the red pill, you will stay in Wonderland and see how deep the rabbit hole goes.. The manufacturers of amps are also part of the collective delusion and queue up to reinforce the narrative.
Sugden:
Gryphon
Plinius
Lavardin
drummerman said:So conditioners/filters clearly CAN make a difference to sound according to the mentioned manufacturers.
They may feel it undermines the sound their equipment produces but it could well be that some individuals prefer the outcome of using them in the context of their systems.
There you go.
CnoEvil said:IMO. The Amp Manufacturers highlight the problem. The brands of conditioners try to mitigate it.....which is usually expensive for power hungry components. My experience is that conditioners often make the sound worse for amps, unless very well designed and expensive.
It's only my experience...and I'm happy for others to give a different POV. It's important that both sides of the debate get aired.
