J
jcbrum
Sospri said:Yep as I thought,
avoiding the question, I rest my case.................
There is no avoidance, Sospri, your case is rejected.
JC
chebby said:Yet again the self-styled AVI 'rep' has colonised another totally unrelated thread for the firm.
the record spot said:Sospri said:Yep as I thought,
What was it? The question I mean...?
mr malarky said:Or it could be "what is the matrix?"
Covenanter said:I wish I could claim all my teeth are my own but they are (at great expense) still in my head. What's left of my hair is still on my head too but it's more silver now than its original blonde. I think I'll buy one of those amps that apparently need 13 amp fuses as that means it's consuming about 3kW and I can dry my clothes by hanging them in front of it rather than using a tumble dryer. (I looked at the pdf of the manual and it proves you can fool more of the people more of the time than even a cynic like me thought.)
Chris
CnoEvil said:Covenanter said:I wish I could claim all my teeth are my own but they are (at great expense) still in my head. What's left of my hair is still on my head too but it's more silver now than its original blonde. I think I'll buy one of those amps that apparently need 13 amp fuses as that means it's consuming about 3kW and I can dry my clothes by hanging them in front of it rather than using a tumble dryer. (I looked at the pdf of the manual and it proves you can fool more of the people more of the time than even a cynic like me thought.)
Chris
Here are independent measurements (from the other side of the world): http://www.avhub.com.au/images/stories/australian-hifi/reviews/2011-03/Musical_Fidelity_AMS_35i_Amplifier_Review/musical_fidelity_ams35i_amplifier_review_lores.pdf
Covenanter said:It consumes c400W so will pull less than 2 amps of a 250V supply. As the output is less than 100W, 300W will be used to heat the environment, which is quite a lot, 1/3 of a 1-bar electric fire. If it makes your lights dim there is something seriously wrong with your wiring.![]()
Chris
CnoEvil said:Covenanter said:It consumes c400W so will pull less than 2 amps of a 250V supply. As the output is less than 100W, 300W will be used to heat the environment, which is quite a lot, 1/3 of a 1-bar electric fire. If it makes your lights dim there is something seriously wrong with your wiring.![]()
Chris
It was measured drawing 414 Watts from the mains.......not enough for your toothbrush though.....![]()
A quote from HFW - "The power consumption of the full Class A AMS35i is obviously more than most transistor power amplifiers; it's enough to make some people's houses' lights dim on switch on."
http://www.bm.rs/Musical%20Fidelity/Musical%20Fidelity%20AMS%2035i%20-%20Award%20HiFi%20World%20January%202011.pdf
It's comforting to know I'm not alone in this.![]()
Covenanter said:My friend! The lights in a house (in the UK at least) are on a different circuit to the sockets. If this isn't the case in your house you need to have it rewired! Do your lights dim when you switch on your kettle which will draw 2kW or 3kW? If they do call an electrician and don't switch anything on until your house is fixed. It is 100% impossible for a draw on a socket to dim lights in a correctly wired house. You may not agree with me about many things but I implore you to accept my knowledge on this. I'm not trying to score debating points; I am concerned for your safety.
Chris
PS I hope you are not by any chance actually running the amp off the lighting circuit.
Does Ireland have ring circuits? Most of the rest of the world doesn't - oz certainly not. Still, lights and sockets should always be separate, no matter what system you use.CnoEvil said:Covenanter said:My friend! The lights in a house (in the UK at least) are on a different circuit to the sockets. If this isn't the case in your house you need to have it rewired! Do your lights dim when you switch on your kettle which will draw 2kW or 3kW? If they do call an electrician and don't switch anything on until your house is fixed. It is 100% impossible for a draw on a socket to dim lights in a correctly wired house. You may not agree with me about many things but I implore you to accept my knowledge on this. I'm not trying to score debating points; I am concerned for your safety.
Chris
Your sensible advice is noted.
altruistic.lemon said:Does Ireland have ring circuits? Most of the rest of the world doesn't - oz certainly not. Still, lights and sockets should always be separate, no matter what system you use.CnoEvil said:Covenanter said:My friend! The lights in a house (in the UK at least) are on a different circuit to the sockets. If this isn't the case in your house you need to have it rewired! Do your lights dim when you switch on your kettle which will draw 2kW or 3kW? If they do call an electrician and don't switch anything on until your house is fixed. It is 100% impossible for a draw on a socket to dim lights in a correctly wired house. You may not agree with me about many things but I implore you to accept my knowledge on this. I'm not trying to score debating points; I am concerned for your safety.
Chris
floyd droid said:Couldnt hear one iota of difference between the two. Now I'm not for one minute suggesting CJ or anyone else who heard benefits, didnt . I can only assume that perhaps dirty mains or how this thing reacts with different amplifiers ( more than likely does with different transistor amps) accounts for positive reports. Conversely , I guess it could have a negative effect with some amplifiers / pre amps , hence some negative reports , dunno tbh.
I may whack the mono blocks through it just for a play around tomorrow , but gut feeling is it will be going under the telly.
floyd droid said:I will find out soon enough tomorrow Cno. If the transformers start glowing like a glowing thing rather quickly I'm pulling the plug. Even though I didnt use it for long my hand was hovering over the pre-amps transformers like someone demented.
I agree with your situation dependent theory , which I tried to explain in my words, kindof.
floyd droid said:Ah now thats given me expectation bias , lol.I will know pretty much within a couple of minutes if things aint quite what they should be. I will use the Tacima purely for the monos , nail the rest of the gubbins into the wall. First off though I will run some gas through everything because my monos take roughly an hr to come up to full throttle , then I will power down and do a quick change over.
