And I thought that a difference between a $5 cable and $25 one was... $20 🙂Vladimir said:Some time ago on gearslutz I read that the difference between a $5 regular computer cable and $25 branded 'touring grade' professional one is a more pliable plastic so it doesn't break too easy from constant handling and kinks. Everything else is the same and it's made in the same chinese factory regardless what the name plate says.
The power cables I got with these JBLs are stupid stiff, but I can't be bothered to change them. However, I did invest in pro grade balanced cables just for fucks sake, price was the same as quality unbalanced patch cables anyway. And indeed the cables are so pliable and jiggly, almost spaghetti like.
Thickness is irrelevant in any scenario. It's audiofoolery.
insider9 said:And I thought that a difference between a $5 cable and $25 one was... $20 🙂
Vladimir said:In your application you have 55W to worry about, which is 240mA at 230V.
The fuses are probably 5A, the Bando transformer is tiny, so if by some chance the 38Wpc LM3886TF decides to use 1,150W out of the socket, the standard 10A rated power cord should be able to handle it.
All is well.
Vladimir said:*biggrin*
Gazzip said:Why doesn’t the OP make his own power cables? It’s hardly rocket science and this way he gets exactly the girth, shielding, colour and... erm... performance he is looking for. Back in the day everybody did this. What’s changed?
gasolin said:Gazzip said:Why doesn’t the OP make his own power cables? It’s hardly rocket science and this way he gets exactly the girth, shielding, colour and... erm... performance he is looking for. Back in the day everybody did this. What’s changed?
Mabye cables are so inexpensive that it's cheaper to buy than make it
Can it be done cheaper by DIY?
People don't make their own of anything up any more. Hifi was once very much a do-it-yourselfers hobby, with kit amps and certainly kit speakers common right until the 80s. I realised just how much had changed when I once innocently told someone to make up their own 5m interconnects if they couldn't find any pre-made with the right plugs and sockets. I could feel the "ARE YOU INSANE, MAN??" stares coming at me through ny monitor screen, not just from that thread's OP but from just about everyone who'd so far contributed.Gazzip said:What’s changed?
jimmy1 said:I've still got a soldering iron but honestly never crossed my mind to make own cables, i might give it a go
