my panasonic 50v20 review ...
By the way what is "just"?
I had been viewing in cinema mode not bad, cross between normal and thx.
Clare Newsome:
Honestly guys, you're going to drive yourself insane if you're trying to judge the quality of your TVs by watching ITV4. The bit-rate - and resulting picture quality - of the broadcasts are typically so low that i'd doubt any decent-sized Full HD screen could render them happily watchable.
Add in the rubbish weather/atmospherics and you've a recipe for viewing woe.
Go watch a nice Blu-ray - or HD channel; or at least a main terrestrial channel - instead. PLEASE!
, its the only channel showing the footie ..
gel:
press "aspect" on your remote , scroll down to "just" and select it .. you should always have it set to just el gelimoto
Clare Newsome:
It has finished now Clare
a nice blu ray
sounds good.
maxflinn:gel:
Max there is no just???, i have auto, 16/9 couple of others then zoom 1, 2, and 3.
No Just.
ok , the irish model must be slightly different then gel .. auto is probably the same thing , although i have both ..strange..
maxflinn:ok , the irish model must be slightly different then gel .. auto is probably the same thing , although i have both ..strange..
Do they both look the same then?
Okay on THX mode on some other channels as well i get a black and white thin strip across the top of the picture, so watching thx mode for me is never going to be a good idea, any ideas what could be going on? Also get blurring images.
maxflinn:yes it appears so..
I wonder what it is for then Max?
gel:
whats your tv source ? sky hd box ? if so do you see the black and white strip when using the tvs built in freesat or freeview tuner ? do you see it with blu-rays ? if its a problem with the tv you should see it with all sources .. check that out ..
maxflinn:D.J.KRIME:GEL do you have the TVs overscan set to off?good question
Yep i have it off at the moment should it be on?
gel:
If you want to stop seeing those black and white line then the answer is YES
D.J.KRIME:gel:
It looks like it has stretched out the picture
Thanks for that, any ideas on what else it does?
gel , you could try it on and off , and see if there is a difference
there wasnt on mine using my humax foxsat as source ..
gel:D.J.KRIME:gel:
yes .. if its turned on whilst watching a blu-ray it stops the tv from performing 1 .1 pixel mapping ...
D.J.KRIME:A basic rule of thumb re overscan is to have it set to OFF for native HD and ON for SD content.
Okay thanks for the tip, appreciate that, cheers
now i gotta go walk some doggies ..
ill leave you in djs capable hands gel ..
good luck dj
well gel , any luck getting your tvs settings to suit ?? im watching avatar now on thx , with contrast and brightness up 3 clicks , and it looks very very nice
