- Jan 27, 2008
- 248
- 1
- 0
I've been doing a lot of research on the amps mentioned above. All sounds good, except for a few potential pitfuls:
1) Only one crossover can be used for all speakers!! In other words, if you use a 80Hz crossover for your fronts, it applies for rears and centre automatically.
2) If sending an HD sound format to the machine to decode, audessey settings will not be operational whilst listening to that sound. Whereas, if you use the blu ray to decode them, and send PCM, audessey settings are available to use.
Why has Marantz done this? It's ok if you have a Sony BDP S550, and you can decode at the player side, but I have a Sony BDP S350, so can't.
It seems daft that they set the machine up to not use what is seen as a main feature on these amps these days, when playing a blu ray disc, but making the feature operational for any other format?
If any of you out there has either amp, can you confirm that these issues actually do nothing to hinder the sound quality?
To be honest, if I'm spending this kind of money, having limitations like this (no other company set their machines up like this, that I'm aware of) really 'puts me off'!!!!!
Anyone help?
Anyone help?
