Lotus notes 8.5 fixup
victordegener
So I'm new to lotus notes, and this question is probably over kill since i am just a user, and don't administer the server, but in another questions it was suggested to try running fixup. So i started googling fixup and found this statement
"Keep in mind that after you set up transaction logging, Fixup is not needed or used to bring databases back to a consistent state."
So I can't help but wonder why you wouldn't need something to fix a corrupted database if transaction logging is set? This suggests that transaction logging keeps databases from becoming corrupt. Is that what transaction logging does? If so how?
Please visit following resolution to know more about your issue and how to solve it:
https://www.repairtoolbox.com/lotusnotesrepair.html Lotus Notes Repair Toolbox
The best way to do it is to rename the file then force a replication from a known good server.
If it is not too corrupted you can do an updall -r and it will rebuild the indexes.
Try running nfixup.exe against it. If that doesn’t work, try ncompact -c against it.
Note: ncompact exists in all workstation installs. nfixup is not part of the client — you can copy it off a server that runs at a similar NBotes version.
Make sure to use the -c option with compact (ncompact -c whateveryourfile.nsf)
Excellent spammage, ladies: now be good chaps and ****** off, would you? Oh, and take your processed meat products with you, please: they're beginning to whiff a bit since they were opened a few days ago.
