Looking for some good cheap options for 2nd hand subwoofers.
Panda
Recently been getting some better audio equipment, picked up some DT770 pro headphones as an upgrade along with a good amp, needless to say i dont want to wear heaphones all the time, even though they sound really good. Grabbed some 2nd hand kurzweil KS-40A studio monitors for cheap and they're giving me a pretty good balanced sound with great highs, especially for the price, but the bass is a bit lacking. I'm saving up for a bunch of stuff elsewhere so i cant really afford a new subwoofer to give me more bass, so im looking for some good second- hand options. I can use my grandfathers spare amp that will deliver enough power for the average 12 inch sub if needed however i would prefer a powered subwoofer, im also going to be using this thing at my desktop pc in a fairly regular sized room, so it dosen't need a ton of power behind it and almost definetly dosen't need to be any more than 8 inches. Looking ideally for something under £60 or so, but i can go a bit higher if something good can be found. Thanks.
Messiah
305
118
19,070
For that budget the Cambridge Audio S80 pops up fairly often on eBay.
I have one and used to use it for my Home Cinema (with occasional music) and found it to pretty decent.
Jasonovich
611
360
1,270
The Edifier SW is very reasonable price at £129 or if you can stretch your budget further there's the Wharfedale's at £175, these are priced at Amazon but you may find cheaper or even second hand on eBay.
Juzzie Wuzzie
244
61
18,870
I ran a Jamo home theatre speaker set for quite some time and was a big fan of the sub that came with it (SUB200 from memory). I expect they sell relatively cheaply on eBay.
