margetti said:In MPod, select Menu, then Connections (guess you've already done this)
Select "Add player manually"
Select "Name" - give it any name you like
Connection mode - keep as the default (Remote)
Select Server - enter the IP address of your Pi
Ignore all other settings (ie leave them as they are) and press Save (top right corner)
If everything is working properly, you should now see your Pi listed under "Configured Players" with the name you gave it, it's IP address, and a bold "wireless" symbol and bold "remote control" symbol. If the wireless symbol is greyed out then MPod can't connect and something is [still] wrong with the set up.
If you do have a bold "wireless" symbol then select Menu again, then Browse, and you should see a list comprising of "USB" and "WEBRADIO"... that's probably as far as we can go for now as you don't have any music stored in the database yet.
Hope that makes sense - am a bit knackered and off to bed very soon! :wave:
The wireless symbol is greyed out, the remote symbol is "bold". The Pi wired, not wireless, so should I expect to see a bold wireless symbol if it was working correctly?
