Dave_
ifor said:SSH isn't much use to me until the Pi can be seen from another computer. Correct?
No.
daveh75 said:ifor said:SSH isn't much use to me until the Pi can be seen from another computer. Correct?
No.
No.
daveh75 said:This is where ssh comes in useful. You can normally still ssh in and use the shutdown or reboot command even if the system is locked up.
margetti said:daveh75 said:ifor said:SSH isn't much use to me until the Pi can be seen from another computer. Correct?
No.
Well, until ifor can get an IP address on his Pi, SSH will be no good which I think is what was being asked...
EDIT - Is your "no" in reply to the first sentence or the second? Just realised I may be misinterpreting your reply...
daveh75 said:I'd start with the most obvious and easiest and often overlooked first. H/W.
I've had network issues before and wasted hours troubleshooting and messing about with configs to find it was a dodgy cable.
Swap the Ethernet cable thats being used to connect the pi to the router, and also try a different Ethernet port on the router and go from there.
margetti said:daveh75 said:I'd start with the most obvious and easiest and often overlooked first. H/W.
Good call!
ifor said:DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 15
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 13
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
done.
daveh75 said:EDIT - Airports assign .2 to .200 to DHCP.
daveh75 said:daveh75 said:EDIT - Airports assign .2 to .200 to DHCP.
Just to add,
Rather than assume the extreme is using defaults, if you launch airport utility click on the internet tab, and then DHCP, and note the DHCP beginning and ending addresses that will make sure we avoid any conflicts.
daveh75 said:OK don't worry about it if you can't find the DHCP settings, we'll just assume its using defaults, which will avoid any conflicts anyway looking at the IPs your devices have been assigned.
One thing we do need is the default gateway (the extremes IP Addy), so if you could run ifconfig on your Mac unless it lists it in airport util somewhere and I'll post up the config changes you need to make
