Just received my Lp 12 back from being serviced. Can someone recommend what tge weight dial should be set to? Grace arm and dynavector cartridge. Thanks
Normally you set the weight to the cartridge manufacturer's recommendations. Adjust the counterbalance weight until the arm floats, zero the gauge, then dial in the correct weight.
