Lg 27 mt 93v smart tv
carter
211
Hello,
was thinking of getting one, of these for the bedroom does any one have one or no if they will go on a wall bracket.
cant find this info online.
cheers
ps think its a currys model so I don't no if there is an alternative model number
SiUK
79
http://www.lg.com/uk/monitors/lg-27MT93V/technical-specifications
Doesn't look like it from the images. And wall mounting is not in the spec...no mention of vesa standard. So I doubt it. You'd have to use one of those 'clamp' type wall mounts that clamps onto the the top and bottom of the tv edges I'd imagine.
carter
211
Yep googled,but couldn't see any mention of wall mounting in the spec didn't no if it was something that was just as standerd.
will take a trip to town and have a look at the back of one
not familiar with clamp system was hoping to use the existing cantilever mount I had already
cheers for replies
carter
211
Had a look at the set in currys today and it dosent have any wall mount holes however the model down (no 3d) has the same casing with the holes for mount.
very strange as in the specs it says the base is detachable.......why would you want to take the base of if you can't wall mount it.....
Don't think there is a similar speced model to this one... :-/
v21rae
I have just purchased this tv and am wondering what the options are for wall mounting? Where can I get a "clamp" mount as suggested?
