FrankHarveyHiFi said:
Im surprised you didn't notice some difference between those you've listed. I find Monster cables dull, and VDH not much better. Never heard Atlas, but I've always liked Audioquest cables (well, I did in the 90's, not sure what they do now). I always found I liked what solid core cables did. Weird how you just don't see many of them around nowadays. I found the Cyrus solid core cable was the only thing that ever sounded good back when I worked at Sevenoaks, nothing else had the same grip and speed. Always seemed to lack a sort of 'fuzziness' that multi stranded cables had, producing a cleaner top end.
As I said, I'm not familiar with Atlas, so I can't really comment. But if you've found something that works in your system, regardless of price, that's great. That's what it's all about. It doesn't matter what it costs, as long as it works.
I've had Monster (Interlink 200s I think) , Van den Hul The Name, Audioquest Turquoise and later Copperhead, Atlas Navigator, my current Computergear AVs (cheap but well made) and QED Qunex 2 off the top of my head. Maybe a couple more. Up to the point I bought the Van den Huls I was "in" with the whole cable thing. Totally bought into it, the 10-15% bit, the difference they could make and then when I saw the WHF Buying Guide entry - I think it went along the lines of how the Name would "increase dynamics..." and generally make a big impact - I was off to buy a set. I'd just picked up a new CDP at the time (Linn Mimik) and decided to change the cable too. I'd been using the AQ Turquoise prior to this with the Linn. Swapped out the AQs, put the Name cable in. No change. Let it "burn-in" (bought into that with cables too), swapped the round. No difference. Eventually sold the VDHs and then the AQs went sometime later.
I bought the AQ Copperheads on the back of a recommendation in a Glasgow shop (Audio Merchants, which I think is no longer there sadly) and there was a minor difference, very subtle. Worth the ex-dem £50 price? Probably not, but they went in. Bought the Computergear ones about a year later and at £7 for a 2m pair, I wasn't expecting the earth, but they were solidly built, albeit not to the same standard as the major brands, but hardly poor either. Popped them in and...yep, they'll do!
Atlas cables were being sold off last year; big discounts and although I missed out on some Titans, I ended up with the Navigators. My rationale was that I'd hope to hear something different with a £200-odd cable. The sound took on a more bloated character, but not massively, again very subtle but would've been rather unimpressed if I'd paid the full price.
The upshot is that the cheap ones are currently plugged in, doing fine and looking a nice shade of blue that matches the carpet! The Atlas ones will be going on Gumtree and/or Ebay soon. Not had the time of late.
It's been said that it's my ears, or my stereo isn't revealing enough (I'm not sure how much more revealing it could've been at the time however...) and in the end that could well be so. However, I know the music well enough and how it should sound. I generally pick revealing systems anyway so know the music in detail, so I don't tend to agree that it's my ears (notwithstanding progressive hearing loss that ageing brings) or that my stereo is lacking in that regard.
By far and away the biggest changes are around core components, then the material and how it's been mastered. Ancillaries such as cables are just that unless you're considering silver vs. copper based in which case there is a noticeable difference between the two. Otherwise, I'd recommend anyone buys a well constructed cable and worries more about what they're playing and enjoying that than the relatively small bits of wires connecting it all up.
EDIT: And I'm sorry for my rather intemperate reply last night. "Tired and emotional" I think the saying went...
