It'd be impossible to tell as your ears would be picking up your own noises and therefore not in a position to detect subtle differences in the sound from your speakers.Vladimir said:I make fart noises with my mouth on the DAC case like on a baby belly? How does it affect crescendos in spymphonic orchestra?
lindsayt said:It'd be impossible to tell as your ears would be picking up your own noises and therefore not in a position to detect subtle differences in the sound from your speakers.Vladimir said:I make fart noises with my mouth on the DAC case like on a baby belly? How does it affect crescendos in spymphonic orchestra?
Try a different experiment.
andyjm said:Theoretically, a DAC could suffer phase variations in the clock if the crystal was subject to vibration - and this could lead to jitter artifacts in the DAC output. I did a bit of Googling, and the effects are tiny - measured in parts per million for very high rates of acceleration of the crystal. Important if you are following Elon Musk to Mars and are wondering about the accuracy of your guidance system during the launch, but frankly a complete waste of time for home HiFi.
QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:That depends how susceptible the system is to vibration, and the quality of the system, but the fact that some forms of damping is on both the cheapest hi fi systems to the expensive systems tells you all you need to know from the perspective of damping and why used. But whether it makes a difference on budget systems, whose sound would be less noticeable, is I think the issue.
+1
Most manufacturers from bottom to high end do engage in some kind of damping for their SS. On higher end gear it is not unusual to find stillpoint feet and full supension PCB assemblies as standard.
DACs are a great solid state example of where vibration can be a real issue. The oscillators (even "low noise oscillators") associated with the clock are extremely sensitive to vibration and shock. Any shock or vibration to these components can produce large phase deviations leading to congestion and improper queing, AKA jitter. Put simply the frequency of the clock becomes irregular. Vibration isolation is therefore of paramount importance for a DAC to operate faultlessly. The big question is always are the errors caused by oscillator vibration audible? I believe I can hear it, but everybody has a different point of view.
Then of course there is the question of capacitor microphonics, which if audible would be a much wider issue...
thats interesting and I agree. Do you know in laymans terms how movement or vibration has the effects on a dac.
The digital to analogue conversion process is cotrolled by a clock (oscillator). This is a computer timing circuit that controls the speed of the digital signal to analogue signal conversion process. The clock tells the audio DAC chip to operate 10's of thousands of times a second. When the DAC chip "fires" at the instruction of the clock it takes the next digital signal (sent from the transport) and creates an analogue voltage that matches it and which can be amplified by an analogue amplifer. This is the basic premise of digital to analogue conversion.
Now imagine that the clock's regularity has been effected by vibrations. The DAC chip fires inappropriately and fails to produce an accurate analogue representation of the digital information. These signal issues associated with "off timing" are known as jitter. Make sense now?
but how is the dacs regularity affected by vibrations. I'm with you on the score vibrations affect non moving electrical circuits, as I understand it exclusively to be the case with circuit designers, but have never understood it. Thanks for trying to explain.
Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:That depends how susceptible the system is to vibration, and the quality of the system, but the fact that some forms of damping is on both the cheapest hi fi systems to the expensive systems tells you all you need to know from the perspective of damping and why used. But whether it makes a difference on budget systems, whose sound would be less noticeable, is I think the issue.
+1
...because the DAC's rate of fire is governed by an oscillating clock which is sensitive to vibration.
QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:That depends how susceptible the system is to vibration, and the quality of the system, but the fact that some forms of damping is on both the cheapest hi fi systems to the expensive systems tells you all you need to know from the perspective of damping and why used. But whether it makes a difference on budget systems, whose sound would be less noticeable, is I think the issue.
+1
how is it sensitive. The mechanism? It's not a physical moving clock obviously.
+1
Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:That depends how susceptible the system is to vibration, and the quality of the system, but the fact that some forms of damping is on both the cheapest hi fi systems to the expensive systems tells you all you need to know from the perspective of damping and why used. But whether it makes a difference on budget systems, whose sound would be less noticeable, is I think the issue.
+1
The crystal resonators which form part of the oscillator circuit do physically resonate. This is why they are sensitive to vibrations.
Al ears said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:That depends how susceptible the system is to vibration, and the quality of the system, but the fact that some forms of damping is on both the cheapest hi fi systems to the expensive systems tells you all you need to know from the perspective of damping and why used. But whether it makes a difference on budget systems, whose sound would be less noticeable, is I think the issue.
+1
Those 'crystals' will continue to oscilate at the same frequency irrespective of external movement. Presumably if they changed then you would end up with no sound at all.
+1
Leif said:Al ears said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:That depends how susceptible the system is to vibration, and the quality of the system, but the fact that some forms of damping is on both the cheapest hi fi systems to the expensive systems tells you all you need to know from the perspective of damping and why used. But whether it makes a difference on budget systems, whose sound would be less noticeable, is I think the issue.
+1
And as you know that is the whole point of a quartz crystal, it has a fixed resonant frequency.
Gazzip said:Al ears said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:That depends how susceptible the system is to vibration, and the quality of the system, but the fact that some forms of damping is on both the cheapest hi fi systems to the expensive systems tells you all you need to know from the perspective of damping and why used. But whether it makes a difference on budget systems, whose sound would be less noticeable, is I think the issue.
+1
No that is incorrect. Those crystals are susceptible to external vibration which can introduce phase variations (timing issues) within the DAC chip, which in turn produces jitter.
Leif said:Gazzip said:Al ears said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:That depends how susceptible the system is to vibration, and the quality of the system, but the fact that some forms of damping is on both the cheapest hi fi systems to the expensive systems tells you all you need to know from the perspective of damping and why used. But whether it makes a difference on budget systems, whose sound would be less noticeable, is I think the issue.
+1
So my quartz watch gains or loses time when I am caning it round the local ice rink?
Vladimir said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:That depends how susceptible the system is to vibration, and the quality of the system, but the fact that some forms of damping is on both the cheapest hi fi systems to the expensive systems tells you all you need to know from the perspective of damping and why used. But whether it makes a difference on budget systems, whose sound would be less noticeable, is I think the issue.
+1
Vibration induced piezoelectric effect on quartz clocks. When a piece of quartz vibrates, it generates an electrical voltage.
Electro said:Vladimir said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:That depends how susceptible the system is to vibration, and the quality of the system, but the fact that some forms of damping is on both the cheapest hi fi systems to the expensive systems tells you all you need to know from the perspective of damping and why used. But whether it makes a difference on budget systems, whose sound would be less noticeable, is I think the issue.
+1
This is true .*good*
http://www.bbc.co.uk/news/technology-39934323
Al ears said:Leif said:So my quartz watch gains or loses time when I am caning it round the local ice rink?
The thought of that happening gives me the jitters..... ;-)
Al ears said:Of course your watch doesn't go faster and it is a good job that any vibration induced jitter cannot be hear.
QuestForThe13thNote said:Electro said:Vladimir said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:Gazzip said:QuestForThe13thNote said:That depends how susceptible the system is to vibration, and the quality of the system, but the fact that some forms of damping is on both the cheapest hi fi systems to the expensive systems tells you all you need to know from the perspective of damping and why used. But whether it makes a difference on budget systems, whose sound would be less noticeable, is I think the issue.
+1
very interesting but I must admit I'm still none the wiser. Can someone explain step by step in laymans terms. What is the quartz, how that happens.
andyjm said:Al ears said:Of course your watch doesn't go faster and it is a good job that any vibration induced jitter cannot be hear.
Well, in principle, the frequency of oscillation (and the speed of your watch) could change slightly with vibration- but the effects are tiny and in audio terms the induced jitter in a DAC because of this is almost certainly inaudible.
Al ears said:Apologies for my poor attempt at humour.
For our non-English posters the expression 'gives me the jitters' means makes one nervous....
Al ears said:andyjm said:Al ears said:Of course your watch doesn't go faster and it is a good job that any vibration induced jitter cannot be hear.
That's a good job otherwise you would have a lot of people who carry Digital Music Players around in their pockets complaining somewhat.. ;-)
