xtsili:cheyworth:
the AS 700 is an integrated amp, so would be very difficult to use two together.
better going for a power amp.
Accorrding to the manual of my speakers it is a no brainer. You simply use the 1st amp for high frequenceis and the 2nd one for the low.
What Cheyworth means is, as your existing Yamaha already acts as a pre-amp (volume control, input selection, etc), you don't need another amp with these on it. You just need the power section to drive the speakers.
Running 2 integrated amps may be possible, but you've got the hassle of matching the volumes between tweeters and woofers, if the Yamaha doesn't have a pre-amp bypass such as I mentioned in my earlier post.
EDIT: the_lhc beat me to it.
