is bi-amping an upgrade?
Bodfish:
Thanks, I will.
I don't think anyone has a problem with opinion, it's just the use of words like 'passive biamping cannot and does not give any benefit whatsoever' being presented a fact rather than an opinion or point of view. And what is 'Naim black magic' BTW?
So, FWIW, in my opinion and experience etc, bi-amping does make a difference. Lots of variables to take into account so go listen for yourself and make up your own mind yada yada yada.
Now, where did that Russ Andrews £16,000 speaker cable thread go?
Well the mere fact that more power will become available to control the speaker drivers as result of bi-amping , isn't it by its own beneficial?
xtsili:Not even with this?
http://www.cyberselect.co.uk/product/1307
I haven't used that device myself, but can't help but think it will bring some compromises in quality, more than offsetting the benefits of using a better power amp.
I think you may be clutching at straws here: a much better solution would be to consider a higher-quality integrated amplifier, or a dedicated pre/power combination.
xtsili:Well the mere fact that more power will become available to control the speaker drivers as result of bi-amping , isn't it by its own beneficial?
No: were you to biamp using another amplifier of the same power and gain as your original amplifier, the speaker drivers will still 'see' the same power.
If you want to deliver more power to your speakers without changing your current amplifier, you need to add on a pair of these if you can find a pair secondhand. A simple amplifier upgrade may be more cost-effective, however.
Andrew Everard:
To be honest I don't get it but I am sure it is the way you are putting it Andrew.
Andrew Everard:
Yes Andrew I know about the MF superchargers but are prohibitively expensive - even 2nd hand
And I understand myself that the way to go is to simply buy a new better amp but I want to make the most out of the current setup, that's why the hassle
xtsili:And I understand myself that the way to go is to simply buy a new better amp but I want to make the most out of the current setup, that's why the hassle
Trouble is you already have made the most out of that amp, you can't take it any further, the amp is the limiting factor in your setup.
the_lhc:xtsili:And I understand myself that the way to go is to simply buy a new better amp but I want to make the most out of the current setup, that's why the hassleTrouble is you already have made the most out of that amp, you can't take it any further, the amp is the limiting factor in your setup.
Necessity is the mother of invention 🙂
the_lhc:
Totally agree.
xtsili:...Necessity is the mother of invention 🙂
xtsili:
Ah but try to knock a wall down with your head and all you end up with is a headache.
And a wall.
the_lhc:xtsili:
Ah but try to knock a wall down with your head and all you end up with is a headache. And a wall.
That's why I posted here, to avoid what you are saying
This is very interesting to me as I was considering going for a Roksan M2 integrated and a M2 power (when it`s released) to upgrade my current bi-amp set up (see sig). Do you think then that say 2.5 K would better off spent on a next level up integrated/pre power combo?
basshound:This is very interesting to me as I was considering going for a Roksan M2 integrated and a M2 power (when it`s released) to upgrade my current bi-amp set up (see sig). Do you think then that say 2.5 K would better off spent on a next level up integrated/pre power combo?
Few may say depending on your speakers but imo, £2.5K would better in an intergrated form (or even Pre-power but normally at higher price)
flakmonkey:
OK Ill put it in my own words:
Basically for a linear system, which applies to a high degree to amps and cables at audible frequencies, then bi-wiring and passive bi-amping cannot make a difference (superposition principle). If you want to get into the physics feel free 🙂
Passive biamping and biwiring fall into the same category.
Active biamping, using external crossovers can and will give some benefit but there may be more cost effective ways of getting a bigger leap in performance than doing this.
This is science, not hifi myth
There is a site online that has measured proof that bi-wiring does make a difference. This is fact. However, whether or not that difference can be heard or is indeed any 'better' is entirely subjective.
Personally speaking, ive found my system sounds better single wired (and ive tried both bi-wiring and bi-amping)
