Covenanter
Tannoyed said:I wholeheartedly agree. Anyone who has visited a Greek island will understand that you can't get a 4" turd down a 2" drain. So it is with speaker cables! Use copper and lots of it so that as much voltage as possible appears across the speakers and as little as possible across the cables. There are no baskets on hand for the toilet paper so use as wide a pipe as you can.
Admittedly my hearing is not the most sophisticated in the world but I can't hear the difference between ordinary thick copper wire and very expensive speaker cable, and neither, I should imagine would most people. Hifi has always been the territory of 'kings new suit of clothes syndrome' and there is an army of people out there ready to prey on the gullible.
The only approach that might help, in my view, is to use Litz wire where every strand is insulated from its neighbours. At high freuencies the electrical signal travels down the outer parts of a wire (known as the skin effect). I don't know how significant this effect is a 20kHz which will be the limit for the youngest among you, but it could conceivably make a difference to both those people and the household pets. By having lots of individual paths in a great number of skins you increase the cross-sectional area of the cable for higher frequencies. We use this cable in the high frequency inverter transformers where I work to reduce lossesin the winding resistance.
Foolishly and in view of the price, I had always imagined that speaker cable was of this construction but it would be seriously expensive and I can see now that it is not (as far as I know).
Thick copper is the route I take and will continue so to do
Skin effects and the like are almost non-existent at audio frequencies. So I agree ordinary thick copper is fine.
Chris
