Question Component Matching for Rega Planar 6/Ania
VinylGym
6
Hi, I am about to upgrade my system and had a couple of questions. I want to opt for a vinyl based system with CD option available also. I currently have the original Pro-ject Debut 3 paired with a Cambridge Audio Azur 540A amplifier, Marantz 6006 CD player, and bi-wired B&W 607 S3 speakers. All the interconnects/speaker cable Etc are premium apart from the poor Project fixed interconnect cables.
I want to purchase the Rega Planar 6/Ania turntable as the central piece around which the system is built (I don't like the Technics styling so the new SL1300G is not on my radar). I am thinking of pairing it with Arcam's A15 amplifier. Is this a good combination? Also, even though I have recently purchased the B&Ws, should I opt for a more premium set of speakers and if so, what would you recommend? I am looking to spend in the region of £1000 for each component. I don't see myself upgrading the Marantz at this time.
RP6/Ania is £1700 Good TT
Spend 50% of your budget on the TT/Phono stage in a vinyl system " Source First "
at this price level IMHO get a demo of a Avid Ingenium & Project X2B with your chosen amp/speakers
Amplifier wise, if you are happy with Cambridge, buy a more recent model although, if keeping the 607s I would look at Marantz or Rotel amps that are within budget.
Speakers, cannot help you with as not enough information regarding rom size etc.
Anyway they are very personal so suggest you get to a dealer and audition some, if possible in your own home.
Turntable wise I would also go for Avid over Rega
What's wrong with the Arcam A15?
Thanks Daytona. Currently, Sevenoaks are selling the Raya P6/Ania for £1155 which strikes me as a great deal. The Arcam A15 has a built in phono stage but I’m not sure if I will need a better one, like you say, to get the best from it.
Are you sure about that price? Can't see it anywhere, is it ex demo? Normally they are £1675.
Arcam phono stages normally good, you will have to try it out for yourself if going for the A15 before spending lots more on a decent separate.
If you are intent on buying a separate why buy an amplifier with one installed?
It looks like that onboard phono is MM while the Ania is MC? You're unlikely to get an integrated with a MC input in your price bracket.
To use with an integrated's MM input you might look at the Rega nd7 instead of the Ania, or with the Ania you have two moving pieces: a phono pre-amp (or step-up) and an amplifier.
That was the What HiFi quoted price but I’ve checked the offer and the price has gone up to £1280 and that is without the cartridge. Looks like I need to rethink this as you guys have intimated!
If you are determined to have a Rega - and they are decent turntables, deservedly popular - then a Planar 6 can come with the newest Nd5 cartridge for around £1500. For £1,000 I think you might find the Planar 3 RS Edition doesn’t lose out much, and includes the same cartridge - and meets your budget.
Get that first, and see how much better your records sound. Then, think about speakers that work in your room/space, with an amp that’s suitable for driving them, with the facilities you need. Please listen to and look at as many speakers and amps as you can, before deciding. You’ll be repaid for years, for the time you invest now, rather than asking us!
Enjoy!
PS. I can’t seem to find whether the 540A has a phono stage - does yours?
Enjoy!
Agree, you'll probably struggle to hear any difference between the Planar 6 and Planar 3 RS assuming same cartridge used on both.
In either case you'd want to get a standalone phono preamp, otherwise you'd be losing out. The ones in your amp choices simply won't do your turntable choices justice.
Enjoy!
I he's running a Debut 3 through it then it must have.
Reactions: nopiano
My 2p. Having recently bought a Planar 6 ND7..Rabbit hole !
I bought it to accommpany my NAIT 50 as the MM stage was apparently magnificent…
It is ! But then I began looking at extracting more from the RP6 and now looking at phono stages to further improve..
I suspect if you buy either the RP3 RS or RP6 ND5 that you must also don justice to the turntable by matching the phono stage as closely as possible.
You can’t buy a great TT then whack it into a generic phono stage.
If you are local to Exeter, and don't mind second hand gear, there's a used P6/Ania for sale at £1175 or thereabouts.
For what it is worth, I demoed it last weekend (as an upgrade from my Technics SL1500C with AT-VM540ML). With the ND5 wasn't that special, but with the Ania it was really good. Pity for the "centre hum" issue. Couldn't really hear it when playing - and didn't really look for it as anyway the price quofor the whole package, £2.3k including Fono MC, was out of my budget - but nonetheless annoying at this price point.
I'm coming at this having been around the house many, many times. The best (but not the most expensive) system I've ever had was Rega RP3/Elys2, Apollo-R, Brio-R and RS2s (or Dynaudio DM2/6 - I had both and they offered different signatures, but were equally excellent).
Frankly, I've never matched the engagement of that system, and so I'm in the process of going Rega again and making a resolution to stick with it, starting with the io amp and Kyte speakers I have arriving today.
The Planar 3 is a sweet spot, and a superb balance of price and performance. It's all the turntable most people need, and the P3RS is excellent value, including as it does the NEO MkII PSU. If you wait a few weeks for the new Brio Mk. 7, or consider a used Elex-R or new Elex MkIV, Rega's built-in phono stages are a step above most, and you'll probably be more than happy with what you get.
Reactions: Entrigo
Thanks everyone. For those interested, I ended up increasing my budget and opted for the RP6/Ania Pro with the Rega Fono MC MK4 phono stage, and the Rega Elicit MK5 amp. After some running in time the system sounds incredible. The only issue now, is that the B&W 607 S3s are not the best matched speakers. They sound a little too bright and clinical for this system. They’ll have to do for now, but when I can afford to, I’ll change them for something more suitable.
Reactions: nopiano and Al ears
... so the system doesn't sound so incredible ... 🙂
Often a good idea to get the ‘front end’ as good as you can, which makes everything else as good as it can be. With small speakers like your B&W you can achieve a lot with careful toeing in or out. As they’re voiced quite brightly, firing straight ahead, past your ears may be best.
Is the room well furnished? The modern trend for hard floors and blinds is brighter sounding than carpets and curtains!
