I am trying to connect my B&W PX7 headphones to my iPad by wire and to listen to them but not working!
Status
Not open for further replies.
The only other thing I can think of is my headphone cable the right cable? I found it in my cupboard alongside some HDMI cables, but it slots in perfectly. I will order that next if the B&W cable doesn’t work tomorrow. Could that possibly cause an issue if not the right cable?
What happened to the cable that came with the headphones? Why buy cables again??
Anything's possible in this story 🙂
You didn't tell us you found a cable in the cupboard Gel!......to be fair, the TRS cable you found is all that should be nnecessary* - but it wouldn't surprise me if they're using some proprietary connector at the headphone end.
*UNLESS, the phones can be used balanced when wired (which is unlikely)....in that case the headphone-end plug would need to have 4- poles - even to be successfully used unbalanced.
Nope, all that is required is a 3.5mm jack cable..... Should be quite simple really.....
Either that cable is duff or someone needs to check the headphone switch settings.
Just waiting to see if it works with a full charge now…
Place your bets now. 🙂
I am going to say it will work, how about you?
I'm not a gambler, but I'd say that if it had any charge, it should have worked.
Maybe the charge needs to be over a certain threshold - who knows what illogical way of working they might be using?
I won't be going wireless anytime soon.
I can see me selling these this time next week.
Status
