I am going to have a little try of valves ...
chebby
1,233
19,195
It might be a completely reburbished/rebuilt valve radio (with VHF/FM), or a very reasonably priced, second-hand, class A, valve integrated that can drive my 90dB Audio Note speakers.
Budget depends on which option I pick, but it will not exceed £500* for various reasons. (Eg. Possible DAC purchase.)
My 'leaning' is for a very nicely rebuilt valve radio with VHF.
*Not even by one penny.
tino
135
10
18,595
Good to hear ... hope you find the sound and nostalgia you are looking for ...
* BTW ... have you seen this ? 40W, valves (albeit a hybrid design), within budget , and a sprinkling of mod-cons which you may find useful
drummerman
540
Cool.
I dont know where you get a reasonably priced, refurbished amp but I have fond memories of the Audio Innovation Integrated I had.
What connections do you need for your DAC?
Macspur
77
Looks interesting Mac www.macsmusic.blogbubble.net
macdiddy
87
proper valve amp but I've found this one which just about fits your budget but don't expect much in the way of features.
http://www.iconaudio.com/main-products/icon-audio-mp-3/
I've always wanted to get into valves at some point having listened to many systems at hifi shows I've attended but they have been amps costing many thousands of pounds but at least I would save on heating bills.
*music2*
drummerman
540
Trawling through ebay for my own amusement looking at the weird and wonderful world of cheap chinese trash the names of said products nevertheless show endless imagination; Nobsound MS-10D ... Intimidation V1 ...
Bloody Chinese :)
Al ears
Moderator
Did you have any preferrence as to the valve radio manufacturer?
There are a few on this website:- http://www.pasttimesradio.co.uk/resradio/restored.html
However a lot of them have been sold as they don't appear to hang around. I would imagine valve amps are more plentiful.
Not that I know too much about them but the Pye Fenman II was very highly regarded if you can ever find such a beastie...
chebby
1,233
19,195
macdiddy said:
£500 is not a great budget for a proper valve amp ...
That's why I would go second-hand.
Anyway, if that's not possible then plan B (fully rebuilt/refurbished valve radio) should be within budget, or the world's gone mad!
drummerman
540
I'd save cash on the DAC (see Hifime's site for some examples ... bloody chinese again but in this case they know what they're doing) and spend the money on the valve amp.
Over budged by 300 quid a nice boxed Prima Luna Prologue Classic Integrated, barely used and top condition for just over £800. Perhaps you can do a deal. 40w/ch KT88's. Emporium Hifi.
Its where my money would probably go after a quick search. Looks good too.
plastic penguin
1,883
230
20,070
I would keep an eye out for a Leak Troughline. Whether it'll have enough connections, I doubt... every review I've read (historical and more recent) has been superb.
chebby
1,233
19,195
Aha! I thought that was your Plan A....
Please note the 'leaning' comment in my first post and the order I wrote about the two options in the first sentence.
The radio is plan A.
A look at ebay shows that valve amps are simply not do-able (even used ones).
Al ears
Moderator
chebby said:
Oh yeah. I am agreeing with you.
Sorry. It's very early still.
It was, but I'm on night shift so possibly a tad more awake... ;-)
I cannot recall where you live chebby but this one (Plan A) is in Bournemouth:-
https://www.gumtree.com/p/amplifiers/valve-tubehifi-amplifier-el34-craft-acoustic-40w-pc-26-kg-new-valves-inc-spare-set/1207179457
insider9
859
404
5,270
https://www.gumtree.com/p/amplifiers/valve-tubehifi-amplifier-el34-craft...
Woooooow!!! Looks great.
Half the distance and I'd be thinking if I should try it for myself :)
Al ears
Moderator
Well, with that £100.01 chebby would have left out of his budget he should be able to afford a courier.... even if it weights 26Kg :)
insider9
859
404
5,270
Don't think I'd trust a courier with a valve amp.
By the way, Chebby I was only joking it's all yours. If it was any closer I'd offer to go up and get it today so you don't miss out though.
Al ears
Moderator
I wouldn't have a problem with courier / amp as it's probably built like a tank ...... the valves themselves, once removed, on the other hand may pose a problem. I note it actually comes with a spare set as well. Imagine enough would survive to make up a full complement :)
If not EL34's are pretty cheap... (x4 matched for around £52)
Infiniteloop
51
This looks like a great place to start. My money would go here Chebby. Good luck, and if you go ahead, I'd be very interested in what you think of the 'Valve sound'.
My bet is that you'll be smitten.....*yes3*
chebby
1,233
19,195
I can only find 'Croft Acoustics' and not 'Craft Acoustics' when searching. No idea who they are are or where they are made.
Any ideas?
plastic penguin
1,883
230
20,070
Little confused, Chebby. Looking for a valve amp or tuner seems go against your hi-fi tenets: Usually you crave small or discreet equipment, yet these valve amps tend to have agricultural aesthetics. Your speakers tend to hark back to a more retro era... is it purely a curiosity phase or is there genuine need for a change?
chebby
1,233
19,195
I don't want a valve tuner. I want a valve radio.
Not replacing anything I am using now. Looking at 'populating' another room with something a bit different. I could just use my old M-CR603 with my JPW Sonatas but that's too easy.
drummerman
540
There is also an Icon Audio Stereo 25 on Gumtree. £250 in Bristol
Can't post links but a quick search should find it.
ASK THE COMMUNITY
