Humax foxsat hdr
I was able to track down a freesat+ box pvr from humax
Having set this up i notice that none of the channel 4 programmes are recieved this includes more4 E4 etc
but every thing else fine.
I tried using one sat feed still nothing even updates doesn`t work.Anyone got any clues other then a engineer visit.
You need a twin feed in order to get updates over the air. A looped single feed doesn't work for that purpose so you need a twin LNB upgrade. Its a current listed issue.
You do need the firmware update to solve several problems, mostly with post codes but it sounds as though yours was accepted anyway.
Regarding CH4 etc, I can't explain that other than to say maybe its dish alignment. Have you look in the Manual Set Up Menu at "Quality"? A high quality percentage is more important than a strength percentage. Maybe if its low you have poor dish alignment and thats you're problem.
Alsone:
as alsone say's could well be an alignment issue, iirc all the c4's are transmitted from the same transponder so the dish would only have to be a small amount out of alignment to lose one transponder!
