Richard Allen said:
				chebby said:
			I would still like to see a manufacturer have the courage to go against 'fashion' and flip the width / depth proportions so that the cabinet has a wider front baffle and less front-to-back depth. These were the 'classic' proportions until relatively recently. I am convinced a wider front baffle used to give better stereo imaging.
OK. I'll do it Chebby. Got the drive units to do it here anyway but they're not cheap. SEAS bass units. I'll keep you informed. :shifty:
I knew you wanted to. As you said when I raised the question here previously ...
"There is an equation, although the exact maths escape me at the moment,  as to the width and the depth of a loudspeaker. The ratio, I believe, is  the diameter of the driver vs the width of the cabinet. Ideally, the  cabinet should be wider than it is deep. This is to allow for '  diffraction'. Unfortunately, 'Er Indoors' dictated that loudspeakers  should have a slimmer profile so, because of market forces, we went  there. As was previously posted, these became reflex designs (with all  the shortcomings), but the ideal is wider than depth."
