You can damage any lead, but usually if an optical lead is damaged the signal doesn't get through at all.
Assuming this noise is coming through the speakers, then I suspect it may be a problem with the muting relay in the amp designed to cut the signal for a second when the channel is changed, and the digital to analogue converters in the amp momentarily unlock from the digital audio signal and then lock on again.
