How many hdmi cables do i need? (hopefully a simple answer) & dvd player choice
barnsleydave:Q1. I assume I need an HDMI cable to connect the AMP to an input source. As I have 2 inputs, the dvd player and the sky box (assuming I dont need for for the tv) I am assuming I just need 2 hdmi cables? is that right? If I later buy a PS3, will I need another HDMI cable?
Yes, that's right, but you'll also need an HDMI from the amp to the TV. Oh, and an optical digital cable between the Sky+HD box and the receiver, as the Sky+HD box only outputs stereo over HDMI, and 5.1-channel only over optical. And if you want to feed the sound from the TV's onboard tuner through the amp, you'll need an extra digital connection there, too.
barnsleydave:Q2. I chose the DB35 as it seems almost
identical to the BD55 and if I'm connecting via HDMI the the ability to
connect via analogue cables wont be needed? Comments anyone?
Correct.
barnsleydave:Q3.
I currently have a PS2 and a nintendo Wii plugged into my existing
set-up. I am assuming they will plug in to the system above with no
problems, without having to unplug other stuff?
Indeed - provided their video is connected by composite or component video, the Yamaha will upconvert and upscale them and output the video via HDMI.
barnsleydave:Anything else I need to consider?
Nope - reckon you've just about got it covered...
Thanks for the reply.
So in summary thats 3 hdmi cables & 2 optical digital cables
Cheers.ÿ
ÿ
