How do i convert albums
I don't really see the point of converting to a lossless format as you have already lost a lot compressing to MP3, I doubt there would be much improvement, re rip the cd with a lossless codec then you are talking....Good Luck
He's not wrong. Once the data's gone in the MP3 compression, you can't get it back....bit like taking out those extra clothes/shoes/books that were stopping your suitcase from closing, then expecting them still to be in your case when you get on hols!
Back to re-ripping all those albums, i'm afraid.
Another good way to describe it, is... Get a photograph on your computer. Resize it software to say half or less the dimensions(Lets say at most 400x300), then save it (as something else).
Close your imaging software, reopen the saved, smaller file, then resize it back to the original size. What do you have? A poor quality pixelated photograph... Same thing happens with music.
JohnDuncan:I prefer Clare's suitcase. No offence...........
None taken. However the picture example is easier and cheaper to reconstruct ™
