Here we go again.... GT50 with screen burn...
Page 17 - Seeking answers? Join the What HiFi community: the world's leading independent guide to buying and owning hi-fi and home entertainment products.
gel said:
:cheers: Strapped very helpful.
No worries.
Hopefully that will make the fan noise tolerable.
I'll be interested to hear how you get on. I've no idea how long my TV will be in surgery, so you may well find out before me.
Just had a look strapped and my tv looks fine, as for the hours I haven't looked in the tv menu but I think its around 350-400 hours.
Still not turned up yet! Sometimes I hear the fan, and other times I think they will not hear it though. Just got and wait and see I guess. I see the Samsung plasma is now out of stock at John Lewis, I hope I don't have to choose a different one.
The guy has just gone and the result is I am getting new fans! :clap: Pretty pleased to be honest, he said they were quite loud and should be able to do it by next Monday. He also said that he would come and do it here, so I am all sorted. Result! 🙂
Nice! Are they going to carry out the other foam fix to help with fan noise too gel?
He just mentioned changing the fans, so I don't think so. He seemed to think changing them would do the trick, I will have to ask if it doesn't. :cheers:
Still a good result though eh but I would have thought it would be pretty easy to install the foam fix at the same time as the fans are coming out, fingers crossed the new fans solve the noise issue though.
:cheers: mate.
beater said:
Nice one gel, lets hope that sorts the problem, who did you contact to get someone out.
:cheers: I contacted John Lewis who then arranged for this guy to come out from a company. He was really good and understood the issue well.
http://www.totaldigital.biz/index.php?main_page=product_info&cPath=43_51&products_id=4766
Thanks @gel
Sadly I've been away all weekend, but I did have an email from JL on Friday and the goalposts have moved... In my direction!
i will know more tomorrow...
Oh dear, 1 step forward, and 2 steps back
Now struggling to get a NKU price match, I'm being quoted that the store that I would like to price match with needs to be within the same distance as my local JL..
Total Digital are some way outside that scope!
Think it's a case of NKU gone mad, and I've pointed out that JL have a store in Birmingham, plus I can buy from wherever I want to!
Let's see what happens eh?
Nice one and good luck!
MrW said:
It just gets better....
Now the 55F8000 is out of stock at JL
Ah dear! :wall:
I am getting my fans fitted this afternoon on a brighter note. :clap:
Good news gel!
I flirted with a VT65, but decided in the end that I wanted to try and get a TV didn't potentially have issues in the coming months (DSE/Fan noise etc)
At this rate, I'll probably end up with a 2014 TV though!
I have just had the foam fix done! Wasn't expecting that, I will report back the results.
The foam fix is two little black strips that go in between the fan and the casing of the TV. This stops it from reving up when turning it off and on and leaves it quiet when on! Result! :cheer: Very happy. I was expecting new fans instead just got the foam fix, it is sorted anyway. :clap:
