gel said:
MrW said:
Thanks Gel
The GT60 is just over a year old... I'm guessing they will want to go down the try and repair first route...
I bought it online from JL (well, the original GT30 came from Norwich JL, but subsequently I ended up dealing with them online) I had to pay £100 to 'upgrade' to the GT50 as my GT30 was a 46"
I don't really want to spend any more on a TV unless I really have to...
Where did you get the price match on your VT65 from?
Total Digital:
http://www.totaldigital.biz/index.php?main_page=product_info&cPath=43_51&products_id=4749
Hispek are doing 10 per cent off at the moment too:
http://www.hispek.com/panasonic/plasma-televisions/panasonic-txp50vt65-free-5-year-warranty-50-neo-plasma-full-hd-3d-smart-viera-television-pd-15144.php
Spending more on this TV is definitely worth it. When you speak to them they might send a guy out first, tell them then you want it swapped for something else then. With me they just ordered a new screen without even telling me! I was very annoyed because I had three already, I then went in store and explained to a manager and then got a good outcome.
In the OPs situation JL are well within their rights to try to repair the TV first gel, in your situation you had previous history of the same TV having issues which they tried to repair which is why they agreed to replace the TV...I would be very surprised if JL agreed to replace the TV without even attempting a repair first. Under UK consumer law they have the right to attempt a repair 3 times before a replacement or refund becomes an option, every retailer I have dealt with in my long list of faulty TVs has gone down this route and I don't see JL being any different in this case.
The OPs GT50 has only recently developed a fault and so will be treated like any faulty TV, I would say they will try to repair it first and foremost which is their right and only if the repair is unsuccessful after 3 attempts or they are unable to repair it will a replacement or refund be the way forward. To go in so heavy handed at such an early stage and demand a replacement will make no difference to their response in my humble opinion as they haven't even attempted a repair yet.
Your situation was very different and you had every reason for demanding a replacement or refund, in this case that situation is a little way off yet no? A little perspective is required here imo and it may well be the case that a repair solves the issue with the TV.
