Help - Blu Ray OR HD DVD or BOTH???
Hi, me again
Finally going shopping later today to buy my new AV equipment
Definatley decided on the Onkyo 605 AV AMP
Need help of DVD Player
PS3 - For blue ray and games console
Toshiba HD DVD player - just checked amazon and HD-EP35 can be bought for £190
Only reason for me buying seperate DVD player is so kids can use it, I can see them breaking the PS3
Reason why I am choosing HD DVD player is I am covered if it goes one way or another
Otherwise I will go for SD player - Pioneer or Denon
Please help before I go out, my head is spinning on this subject (probably about 11ish AM)
Am I right to say HD players are not multi region?
Sanjay (D4774NI)
Almost correct. the players are region controlled when playing DVD's (there are craks for some). But HD DVD's are not currently region coded.
This makes sense to me, too. But remember that whatever HD player you choose, it'll only ever play Region2 DVDs (until some kind person comes up with a hack....)
Oh, and some Blu Ray discs are Region free (there are a number of sites that list 'em including Movietyme and http://bluray.liesinc.net/)
Sounds like a decent plan to me although I might make one suggestion. You might want to consider saving £70 and going for the EP30. It gives identical picture quality to the EP35 and uses the same upscaling chip and can decode DDTrueHD as PCM over HDMI. The advantage of the EP35 are the analog outputs and the ability to bitstream HD audio but are they worth it? You wouldn't use the analogs with an Onkyo 605. So far, the only studio that has used DTS HD MA is Fox and they're Bluray exclusive. So the only real advantage is the ability to send DDTrueHD as bitstream.
[quote user="FuzzyinLondon"] So far, the only studio that has used DTS HD MA is Fox and they're Bluray exclusive. [/quote] Not correct. I have a HD DVD with DTS Master 7.1 on it and it rocks. Pan's Labyrinth US version.
I stand corrected and does make the EP35 a good prospect if studios will continue to back the format with good quality discs with HD audio. Not sure how long that is going to last though.
Just to give all an update
Decided when I was in the shop
What do I actually watch
I watch SD DVDs
Dont own any HD or BR DVDs
I decided on a Denon 1940 DVD player and I am happy with my purchase and it does fit my purchase and does the job perfectly.
I will at later date buy a PS3 but it is not high priorty
Thanks for all who helped
Sanjay (D4774NI)
