- May 23, 2009
- 63
- 0
- 0
Hello,
Ive decided to start up a new thread for this issue, so to attract more help.
I recently bought myself my first proper TT. It comes bundled with a free intercconnect that has an earthing wire built in at both ends to connect to my amp/TT. This works fine. However Id prefer to use my own Russ Andrews cable as its much better quality, when I use this I get a buzzing sound as Im guessing my TT isnt earthed ? Ive tried just using the cable that came with the TT, just using the earthing wire bit while using the Russ Andrews cable but I get that buzz again. The same with another cable I had spare.
Where can I buy a seperate earthing cable from ?
Ive looked everywhere online with no success. I need one with connectors on both ends, they look like hooks, I dont know what they are called.
Hoping someone can help !
Stephen
Stephen
