What is your HiFi tip of the Day?
Jasonovich
2,248
1,572
6,070
PCs are notorius for noise, I never had an issue when I was listening to music on JRiver Media Centre via directly from the DAC, because the default setting was set to Primary Sound on the PC for the Eversolo but Communication was set to all other devices.
When I started to listen to podcasts or music on Youtube, the sound was clear for the first 10 minutes and then it started to deteriorate, and I was getting crackle and distortion until it became inaudiable; I thought at first, it was an earthing problem, so I purchased USB grounding Isolated - see below
I thought this had worked, my initial listening was less than an hour but after extensive listening, the crackling and distortion came back. I even changed the mains cable, that didn't help either. I knew it wasn't the Eversolo USB connection because when I wasn't using the PC and listening to my music connected to the USB through the digital transport, everything was OK. So the problem was obviously PC related.
I reverted to switching the USB from the PC Pcle Card to one of the USB slots on the motherboard, nope same problem, the USB Card was drawing its power from the sata cable and I was thinking, there might be a grounding problem there, I decided to change it for one one that is self powering, i.e. USB Pcle card drawing it's power from the motherboard rather than sata/molex cable from the PSU - see beow
This wasn't logical because I already tested the supply from the motherboard, why would separate card drawing the same supply from the motherboard make a difference(?) but I was desparate to resolve this issue, even if, I needlessly spend another £40 on something that would prove fruitless, Jason logic!
Yes that proved to be pointless, then I stood back, you're not thinking PC, like the elementary stuff.....like conflict in driver software, s**t, I've been building PC's since the nineties and I can't get the basics right!
Of course, the problem was with the software, having drilled down into Windows 11 driver settings, I can see there were a whole host of other devices using the sound settings and these were conflicting, and the cause of the distortion.
So my tip of the day and if you are a PC (or Mac) user, and you're experiencing issues with the sound quality. The first port of call, is to open the Device Manager Application (I'm not sure what is the equivalent for the Mac OS/Ubuntu/Linux but I suspect not too dissimilar) and as highlighted in yellow, select the option to disable the device, so effectively, the only sound device that is operable is the DAC.
Phew!!! Halilullah
Speaking of which, here's Alexandra Burke to sign me off 🙂
Well it's less a tip and more just a general philosophy but don't worry about the haters and the people that tell you your system or choice of music or speakers or whatever aren't "audiophile" enough. Just enjoy your music for what it is and your gear for what it is and spend less time focusing on how the sound can be improved and more time on simply enjoying it for what it is.
Mike Betts,
You can quote me on it.
PCs are notorius for noise, I never had an issue when I was listening to music on JRiver Media Centre via directly from the DAC, because the default setting was set to Sound on the PC for the Eversolo but Communication was set to all other devices.
I thought this had worked, my listening was less than an hour but after extensive listening, the crackling and distortion came back. I even changed the mains cable, that didn't help either. I knew it wasn't the Eversolo USB connection because when I wasn't using the PC and listening to my music through the digital transport, everything was OK. So the problem was obviously PC related.
I reverted to switching the USB from the PC Pcle Card to the motherboard, nope same problem, the USB Card was drawing its power from the sata cable and I was thinking, there might be a grounding problem there, I decided to change it for one one that is self powering, i.e. drawing it's power from the motherboard rather than cable from the PSU - see beow
So my tip of the day and if you are a PC (or Mac) user, and you're experiencing issues with the sound quality. The first port of call, is to open the Device Manager Application (I'm not sure what is the equivalent for the Mac OS but I suspect not too dissimilar) and as highlighted in yellow, select the option to disable the device, so effectively, the only sound device that is operable is the DAC.
Phew!!! Halilullah
Exactly so. Audirvana built their business on this philosophy...👍
Take advice from successful people, not failures!
Tomorrow's tip: Clean your ears out.
Monday. Switch the TV off. Soap operas won't improve your standard of living. Listen to music instead!
Tuesday: More things are lost by indecision than bad decision. Go for it.
Wednesday: Cash in the hand is worth two cheques in the post!
I guess it's more a case of utilising whatever you have at your disposal. I had a streamer in my system a few years ago and ditched it in favour of a PC as it's far more versatile.
That’s true. I only ever see issues about noise and settings, and DAC incompatibility, but then there must be thousands like yourself who have no problems with a PC. And I’ve read posts from a few people who make the PC do super-hi-powered things like a Chord DAC with umpteen taps. A bit over my head though! 🤯
PC is just a Swiss Knife, it does amazing things 🙂
Reactions: DougK1
I've had a PC in my hifi chain for over 10 years, using either a digital coax out or a USB connection feeding an external DAC. I have never had any issues with this 'noisy' environment leaking into to the playback stream. I occasionally use headphones so I'm certain I would have heard noise if it was there.
I've had a PC in my hifi chain for over 10 years, using either a digital coax out or a USB connection feeding an external DAC. I have never had any issues with this 'noisy' environment leaking into to the playback stream. I occasionally use headphones so I'm certain I would have heard noise if was there.
Very true. I have bought a couple of USB reclockers/ clean up devices in the past and never heard any improvement...
Any half decent DAC designer knows the power line from USB connection needs to be isolated or regulated to prevent noise getting through to the DAC.
Bit perfect software on a PC is a perfectly valid music source in my opinion 🙂
That's because you don't go out of your way looking for solutions for non existent problems.
Reactions: DougK1 and nopiano
Audition!
It doesn't matter how many starts a magazine gives a product, what the man in the shop tells you, or what people say on a forum. The only thing that counts, does it sound good in your system, in your room?
Reactions: Oxfordian
My tip of the day is simple solution to those agonised active speaker owners, who have to manually switch on the power button for each speaker and especially tight spaces where you have to lean over awkwardly to get to the switch.
Fret no more!
Get yourself a cube extension Lead 13A 3250W with the power switch on the top is the solution.
Switch on the power button on both speakers then run the active speaker cables to the cube extension lead - ensure it is switched off from the main supply when you do it.
One button for two speakers - perfect 🙂
Getting your fingers behind the speakers was an absolute pain.
Do make sure it's 13 amp, there are 2.5 amp versions avoid those. Also make sure it has RoHS certification.
Update:
Ah silly billy 2.5 amp is actually referring to USB maximum power. 🤣
Reactions: Revolutions
If you can’t have the system you love, love the system you have.
There are more important things in life than hi-fi.
I completely agree with this. I really love music, but it isn't the most important thing in the world. If your life does revolve around HIFI, to the point where it becomes an all consuming obsession, it might be time to take a step back and recalibrate your aspirations in life. I've said it before, but if I was a multi-milionaire, I would never listen to music, as there would be endless things to occupy my time. Because I'm stuck in my mediocre life, as many are, there is time to listen to music, but I do have several other hobbies etc.
