Deleted member 2457
As above, most of you have seen my setup, I can't afford much on installation. I was thinking about copying BB's setup.
gel said:As above, most of you have seen my setup, I can't afford much on installation. I was thinking about copying BB's setup.
Did it? I think I will need a job to afford my own place. Just been looking at the Sony 40 projector can afford that, now the screen, which ones do you have to go for?Series1boy said:gel said:As above, most of you have seen my setup, I can't afford much on installation. I was thinking about copying BB's setup.
big bro's setup cost around 20 odd K I think... I thought you were getting your own place?
gel said:How much does installation cost on all this?
Cheers mate!Series1boy said:gel said:How much does installation cost on all this?
id install it all my self. I used to be a structured cabling and sever engineer, so I'm pretty good with wires...
you don't have to go as far as bb; you need a projector, screen and atmos speakers, AV reciever(atmos and dtsx) installing and you could hide the wires in trunking, but it won't look pretty...
it will be expensive if you get a pro to fit it, not sure on costs though.
Got a link to a good one? Cheers.simonlewis said:Couldn't you just get a short throw projector and put it on a stool/stand and have a manual pull down sceen screwed to the cieling, no need to spend too much.
*good*macdiddy said:https://www.amazon.co.uk/gp/product/B004LSBY9I/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
for the money it's well made, looks good and produces an excellent picture with my Optoma projector.
*music2*
gel said:Did it? I think I will need a job to afford my own place. Just been looking at the Sony 40 projector can afford that, now the screen, which ones do you have to go for?Series1boy said:gel said:As above, most of you have seen my setup, I can't afford much on installation. I was thinking about copying BB's setup.
I am getting help from my doctor now so I will look into it - cheers! I have to write a list of my aims and the barriers for the next year. So that will definitely go on the list.nugget2014 said:gel said:Did it? I think I will need a job to afford my own place. Just been looking at the Sony 40 projector can afford that, now the screen, which ones do you have to go for?Series1boy said:gel said:As above, most of you have seen my setup, I can't afford much on installation. I was thinking about copying BB's setup.
no. you don't. there is thing called housing benefit? along with esa i get housing benefit and i have been living alone 2 years come may, and i'm only 22! with plenty of money left each month for some purchases, and most to pay off my purchases on credit card(s)
Do you mean write a signature in?chebby said:Gel, can you edit your signature to remove the big empty area that follows your posts?
How about the cheap Epsom? What screen to go with that? Will it hook up to my home cinema system?bigboss said:You don't need to spend a lot for a projector system. Sony HW40, or the newly launched HW45 is a superb projector for the money, hailed by reviewers as the best projector you can buy for under £2K. Most of my budget went on furniture and installation.
Screen depends on how much dark you can make your room.
Are you in a house or flat? Are you on ESA?nugget2014 said:gel said:Did it? I think I will need a job to afford my own place. Just been looking at the Sony 40 projector can afford that, now the screen, which ones do you have to go for?Series1boy said:gel said:As above, most of you have seen my setup, I can't afford much on installation. I was thinking about copying BB's setup.
I knew you were 22 from on AV Forums.gel said:Are you in a house or flat? Are you on ESA?nugget2014 said:gel said:Did it? I think I will need a job to afford my own place. Just been looking at the Sony 40 projector can afford that, now the screen, which ones do you have to go for?Series1boy said:gel said:As above, most of you have seen my setup, I can't afford much on installation. I was thinking about copying BB's setup.
Okay mate - cheers! I will just stick to my OLED then.ellisdj said:Gel you would hate a projector if you don't do it properly. I wouldn't bother honestly
gel said:Do you mean write a signature in?
how's this?spiny norman said:gel said:Do you mean write a signature in?
Put in a signature and/or remove all the spaces: go into your profile, highlight the whole of the area inside the signature box and press delete. All that blank area is taking up a lot of page-space every time you post.
