matt49 said:pauln said:I'm not sure why you think a psychologist would be needed in order to conduct blind testing - what psychology is involved?
An engineer or technician would be needed to set up the test and to ensure it was carried out under controlled conditions. A mathematician would be needed to work out the statistical significance of the results. A psychologist? Please enlighten me.
I suggest that you will give no credence to those tests referred to by MakkaPakka because you don't like the results.
If you want to find out by means of blind testing whether people prefer amp A to amp B, you are, in effect, assessing people’s responses to a range of auditory stimuli. Testing of this kind is called sensory evaluation testing. It’s widely used in the food and cosmetics industries. Its scientific underpinning comes from a sub-discipline of psychology called psychophysics, i.e. the study of the relation between sensory stimuli and psychological responses. (Psychophysics was founded by the great German psychologist Gustav Theodor Fechner in the mid-19th century.)
Sensory evaluation testing involves a number of non-straightforward issues, including: how do you select participants? How do you prepare them for the tests? What questions do you ask them? How do you present the stimuli, e.g. in what context and for how long? How do you evaluate the results? A lot of thought goes into achieving a maximum of neutrality and catering for people's cognitive biases. (For instance, people will tend to react more strongly to the first of a pair of stimuli.)
So this is why psychology isn’t only relevant to blind testing of hi-fi; it’s the discipline that underpins any robust and successful testing.
You wouldn’t need a mathematician by the way, as any respectable undergrad degree in experimental psychology includes the study of statistics. I grant you would want an electrical engineer though, to ensure the equipment was working properly, levels were matched etc.
Matt
That's interesting and makes sense. I thought that it would be straightforward in that you would sit someone in a chair and ask them which was which - if the differences are so apparent (or night and day). Would that not count as a valid test then?
