This will seem an odd question, but I'm hoping someone can help me. Basically I'm having trouble getting sound out through the TV (and thus through the Denon)!!
I have a old Panasonic TH42PX60 TV. This obviously has a HDMI output, which is connected to the 'monitor' input on the Denon. The Denon, for a reason I can't fathom does NOT have any 'TV' specific analogue inputs!! (why is this!) They only input for any TV sound is a digital TV optical input. This seems silly to me, but I thought, no problem I'll use one of the other analogue inputs on the back - in this case the 'SAT/CBL' input.
I have set the 'Quick Select 2' to remember the SAT/CBL input, the 'surround mode' (NEO 6 cinema) and the volume so when I turn on my TV the sound will come out. This works fine.
However, whenever I turn my TV on and the amp (even pressing Quick Select 2) the amp will first select SAT/CBL and then switch to the 'TV' input (once the TV is on) that obviously has no signal going to it! So I have to select Quick Select 2 again on the remote!!
I can not for the life of me stop it from doing this! I have tried turning on the HDMI Control function on both the amp and the TV, and I've tried turning this off! If it's off, the input stays at SAT/CBL, but the TV will (despite being told to turn on to the DVB channels) then change its input to the AV - or the Denon screen - showing the input etc, so I then have to press the AV button on the remote to go back to TV (DVB) mode!!?
This can't be right surely!? I want to turn my TV on and for the Denon to select SAT/CBL input and for the sound to be there - not have to re-select an input that I had already asked for!! Ideally I'd like to turn my TV on and for the amp to come on with the correct input (obviously if both are on standby) and I thought the 'HDMI control' functions on the amp and tv should do this - but they don't!!
So just getting the TV to stay on DVB channels and for the amp to stay on SAT/CBL input would be a good start!!
Any ideas??
Any ideas??
