- Aug 10, 2019
- 2,556
- 5
- 0
Hi guys, after many hours of re-wiring last night I finally switched on my Cyrus system only to be greeted by popping banging and sparks from my 8vs2, due to the power cord not being properly inserted i think! after a quick switch off it appears that the 8 vs2 is very poorly and is showing a solid amber light on the power light with 2 green lights at either side of 12 o'clock on the volume dial! after referring to the manual I cannot even find a mention of the amber power light in the fault codes!
Does anyone have any clues with regards to the damage I may of caused and has anyone experienced the amber power light before and if so is it repairable?
Thanks, Marcus.
Thanks, Marcus.
