Compact amp for rDac/Airplay (and Sky box)
antcg1
12
Hi there,
I was wondering if anyone could recommend a compact mains-powered amp that would suit the following set-up?
At least two switchable line-in inputs:
1) From Arcam rDac running Airplay through an Airport Express
2) From Audio from Sky+ 1Tb box (assuming the Sky box's L/R phono out for this?)
Ideally not much bigger than the Denon UD-M31 - which I'm currently using for the Sky bix - but which doesn't have a free input for the Airplay, hence the need for a new amp.
I intend to use it to run a pair of Q Acoustics 2010i or similar. It's basically for a small-ish living room - 50-50 mix of music through the Airplay/rDac and TV through the Sky Box.
Really appreciate any ideas. Thanks in advance!
Antony
If all you need is another input, why not just add a switch?
http://www.amazon.co.uk/Stereo-CD-AUX-switch-3-way/dp/B000KVODHA/ref=sr_1_3?ie=UTF8&qid=1335534057&sr=8-3
Seems to have decent reviews but I'm sure you can spend more if you want. 😉
Edit - Doesn't the Sky box have digital out that could also go through the rDAC?
