Cleaning grubby woofers?
CnoEvil
556
14
This might be one for the speaker designers on here.
What material is the woofer made of, and what sort of stain?
If it doesn't effect performance - tread carefully.
jiggyjoe
9
Just use a damp cloth and wipe gently.
Do not use any alcohol or other solvent based cleaners as they could react with the msp (a type of plastic) cones.
roger06 said:
Hi
How should I clean grubby marks of the woofers on my Dynaudio Audience 52SEs?
Damp cloth? alcolhol wipe?
thanks
If they are ground on marks I'd leave well alone or have a word with a dealer. If it's just dust carefully use a vucuum cleaner to suck off loose dust, or if it can be reversed, to blow away.
roger06
374
shropshire lad said:
I usually clean my grubby woofer in the bath , after he has had his morning walk . What ? What did I say ? Nick
LOL !
