Thanks for the advice Trevor I see what you are saying.
My initial systems was going to be either a Cyrus setup consisting of the Mono X amps, pre amplifier, and the DAC cd player, or the Quad 909 setup with the cd player.
Then I started reading up on Plinius and thought my budget can expand to buy the pre amp M8 and power amps P10 and buy the CD101 later. I was going to auditons these, but a friend of mine put the spanner in the works and started to talk me about Class A.
Basically I'm confused now.
My existing system dates to the 1970's. For example A Pioneer SA-8100 integrated amplifier 40 watts RMS, matching tuner and a NAD C541I CD player. The amp is faulty now. gave me many years of good service and loved the sound. Now it cannot be repaired due to parts not available etc.
I only want to spend this kind of money once and not keep on upgrading. Therefore I'm after a CD player, and amplifier setup (Being intergrated or pre, power combination).
Speakers will come later as I have some MS908i's which I want to get some use out of before I upgrade those.
The type of music I listen to from Classical, R&B, Jazz, and Bhangra. I would like a clear detailed sound, with a nice hard hitting controlled bass line where you can feel the music and enjoy it, ie the bass gliding through the floor boards etc. (Wife and Neighbours not a problem 🙂)
Any thoughts?
