Can you recommend small banana plugs?
madeinstein
74
My shelve has is only 40cm deep and I'm trying to find the smallest banana plugs to see if I can fit Yamaha 863/763 receiver there. I can move it a bit from the wall to gain a bit extra space.
madeinstein:My shelve has is only 40cm deep and I'm trying to find the smallest banana plugs to see if I can fit Yamaha 863/763 receiver there. I can move it a bit from the wall to gain a bit extra space.
Wouldn't it be easier to use the bare wire?
If I don't find small plugs that's definetly a solution..
I'm still hoping that someone will reply to this topic regarding Yamaha upscaling before I decide which one to get..
