buying first time Turntable/pre amp/speakers advice please
kubalee79
Hello all,
Apologies in advance if this comes up as a duplicate post
for some reason my first post has disappeared.
anyway,im currently looking to purchase my first TT
After hours and hours of looking at reviews,this is what i think im going to settle on
Rega rp1
pre amp (not sure.maybe the rega preamp)
Q acoustic 2020i
I have around 1000 euros to spend on this
Would any of you wise souls be able to give me recommendations please?
does this sound like an ok set up?
any alternatives you could recommend?
what cables would be best to go with this?
thanks in advance
lee
Petherick
122
18,595
You'll need an integrated amplifier to power the speakers too. The pre-amp provides equalisation and increases the level of the signal from the TT up to 'line level' only. So if you were to choose an amp with in-built phono stage you won't need the rega pre-amp.
kubalee79
just goes to show i know absolutely nothing!
would you be able to recommed one?
what do you think of the setup above?ok for a starter set up?
thanks for taking the time to reply to my post
much appreciated
B
BIGBERNARDBRESSLAW
Pro-ject Debut Carbon would be a better turntable. (£269)
I would buy an integrated amp with a built in phono stage. (others can advise better than me on a good one in your budget.
Q Acoustics 2020i are great speakers (I'm currently selling mine on eBay), but also consider Dali Zensor 3's ( I got mine for £239)
You should find an easily good enough amp for £250, then you've got a bit of cash left for speaker cable. Some Van Damme Blue or 4mm OFC would be plenty good enough, then you're away.
respe
Whats the secondhand market like around you?
Failing that, stay with deck and speakers, and look for a denon integrated with phono stage that falls in budget.
kubalee79
second hand market is practically non exsistent here
so this is what i was thinking of getting
http://www.maplatine.com/fr/catalogue/platines-vinyles-4/platines-vinyles-manuelles-6/rega-60/platine-vinyle-rega-rp1-performance-pack-721.html
http://www.fnac.com/Marantz-PM5004-noir/a2894100/w-4
http://www.darty.com/nav/achat/hifi_video/enceinte_hi-fi/enceinte_compacte/q_acoustics_q2020i_blanc_x2.html
what does everyone think of this?
many thanks to all
Petherick
122
18,595
And don't fret too much about cables at the moment. Though obviously you'll need some ;)
Your choice of system looks good to me. Can you audition - I take it you're in France?
kubalee79
http://www.son-video.com/Rayons/Amplificateur/Denon-PMA520AE.html
what about this one? do the job?
yes im in france.
think it will be difficult to test the TT but should be able to test the amp and speakers somewhere
probably not with a TT though
Thanks for your advice
respe
I personally prefer denon amps to marantz, strange, as they are the same company. Dont worry about cable too much, if you can find van damme at the right money (2.5 mm for shorter lengths, 4mm if longer) its all you need for any system.
