Bourne trilogy dts hd
TitusG
61
Has anyone else got any of the three Bourne blurays and can select dts hd? I have the Sony bdp760 outputting audio through analogue cables and although the manual says it can decode dts hd, I can't select it from the audio menu on the disc. I just get: dts 3/2.1 48khz (unless this is it?) instead of dts hd.
These are the only dts hd discs I have. My others are Dolby true hd, which is a selectable audio format in the menus.
hammill
212
Mine automatically plays as DTS MA on my Oppo 83. I am using the HDMI cable. I dont even see the audio menu, where is that?
Jonnyhifi
14
TitusG:
As posted on a thread not too far away, make sure your player's BD audio settings are set to Direct and not Mix. That might help.
TitusG
61
Jonnyhifi:TitusG:
Ahhhhhhhh yes, thats done it. Thats much better.
Sorry, didn't realise it had been covered before. Must have missed that thread!
Jonnyhifi
14
No problem, I just thought I'd better ackowledege d4v3pum4's answer on the 'Denon AVR 2310 and no Dolby/DTS audio lights on the front panel display'' thread further down the Home Cinema threads page
Glad it worked.
